2012ex Performance issues
Old May 12, 2014
dmeeu's Avatar
dmeeu is an unknown quantity at this point
I have a 2012 Civic EX. Occasionally it won't accelerate. Just lags a lot. It's temporary and eventually goes back to normal. It has 42,000 miles on it and the engine is not throwing any codes. I have not accidentally pressed the Econ button, but the performance is similar to when I press it and forget to turn it off. Anyone have any suggestions?
Sincerely,
Dave M.
Old May 12, 2014
Re: 2012ex Performance issues
Brake Override System.
Designed to cut power if it senses that the accelerator pedal MIGHT be stuck (accelerator pedal is already pushed down, then the brake pedal is pushed).
If you rest your left foot on the brake pedal, you may cause this to happen.
We seem to have quite a few customers that have had to (re)learn how to drive with only one foot.
Mostly happens with older folks that drive with both feet, ride the brake pedal a little bit and eventually it won't let you accelerate.
Thanks, Toyota!
Other than that, I haven't seen or experienced any issues here.
HTH
Old May 26, 2014
dmeeu's Avatar
OK. Thanks.
My daughter drives the car. She says it mainly happens when she changes lanes. She drives like her mother i.e. Aggressive. It makes sense she could be covering the brake whan she's making her move.
Dave M.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
sergio73
Jun 23, 2015 03:21 AM
MegaBassX
Jun 11, 2015 08:52 AM
