2007 Civic starter
Old Feb 23, 2013
Ralph48's Avatar
Ralph48 is an unknown quantity at this point
2007 Civic starter
I have a 2007 Civic EX with about 80,000 miles on it. When starting the vehicle and after the engine is running the starter continues to run for a second or two. The vehicle has done this for the last 4 years however it is now doing it for a longer duration, about 4 seconds. Any ideas as to what could be wrong? Bad starter?
Old Feb 23, 2013
Re: 2007 Civic starter
Let go of the key when it starts?
Anything aftermarket or non-factory in it?
Not a common issue here.
Sounds like it might be needing some electrical checking to see if it is still receiving power to the solenoid when it does this.
Old Feb 24, 2013
Ralph48's Avatar
Nothing after market. And yes I let go of the key.
Old Feb 24, 2013
I'd connect a test light to the one wire for the solenoid and see how it acts.
Would be a PITA to actually connect on the starter to test.
Convenient connector is next to the master cylinder reservoir, it's only got one wire in it. You can't miss it.
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Cilvic
Nov 15, 2001 04:54 PM
WeRkX
Nov 1, 2001 10:33 PM
