Manual shift issues
Manual shift issues
I have a 2006 Honda Civic Ex. I have a 5 speed tranny and I stopped suddenly behind someone but was only going about 15 mph. When I tried to shift to 1st gear, I was no longer able to. I tried 2nd gear and wasn't able to as well. I am unable to move my shifter all the way to the left to access first and second gear. All it can do is center and move right for 3rd, 4th, 5th, and reverse.
Any ideas?
Any ideas?
Re: Manual shift issues
Look on top of the transmission where the shifter cables attach.
See if something fell into the cables or levers that is obstructing movement.
Have someone move the shifter while you watch what is going on.
Im having the EXACT same issue on my 08 Civic LX. I came to a stop, nothing unusual, and the issue started. Its intermittent. All of a sudden it will start working again like normal, no grinding or shift issues at all, then when i start to slow down and put the shifter in neutral, its like a wall prevents me from moving the shifter to the left in neutral. Like the OP, i can only access 3rd, 4th, 5th, and Reverse. I purchased a new set of shift cables and bushings and hope that solves the problem. Please let me know if find out what the issue was!!!! I will do the same!
You just... bought.. shifter cables... hoping.. they were going to resolve the issue? Aren't those expensive. Find out what the problem is before you start tossing parts at it. Follow ezones instructions.
