2010 HONDA CIVIC STRUT REPLACEMENT - Does it fall under warrenty
Old Nov 14, 2012
amaran's Avatar
amaran is an unknown quantity at this point
Hi,
I am a Second owner of a 2010 HONDA CIVIC it is under 36000 mileage and 3 year warranty. My Front Right wheel needs a suspension replacement after I felt alignment issues in my car.
Does my strut replacement gets covered under Manufacturer's warranty? When I checked the Body shop they mentioned it is a wear and tear problem and is not covered by manufacturers warranty.
Please advice.
Old Nov 14, 2012
Kennykid2002's Avatar
Kenny the Ricer
Re: 2010 HONDA CIVIC STRUT REPLACEMENT - Does it fall under warrenty
1) If the warranty is properly transferred to you.
2) Read the warranty booklet. It will tell you exactly what is covered.
3) If it isn't inclusive enough, call the service department of your local dealership and ask.
I've been to a dealership with a warranty, and they told my that my front struts were covered, but the rears weren't.
Your best bet is just to call them.
Old Nov 14, 2012
Only a dealer is qualified to tell you if it is covered under factory warranty. Or not.
You have 3/36 AND 5/60 for powertrain. Hondas "Powertrain" covers some things that some other manufacturers don't cover, like wheel bearings on the front are typically covered with Honda, but not others.
They look at the car, run the VIN inquiry, submit a part number in the warranty inquiry. The system then determines if the submitted part number is a covered item.
But since you mentioned a bodyshop, that leads me to believe it could be accident related, and that would not be a factory defect. Therefore, not a warranty matter.
Old Nov 15, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
My 2002 civic has 86K and is 10 years old. Are you qualified to tell me if it's covered under warranty?
Old Nov 15, 2012
Factory warranty? Why sure. Your answer will be:
Or not.
Old Nov 25, 2012
D Murphy's Avatar
D Murphy is an unknown quantity at this point
Since you mentioned body shop, I'm wondering, was the vehicle wrecked in that area? If it was damaged in a wreck, it's not covered. If it was not, it most likely is.
LionSpratt
Jan 29, 2017 11:07 PM
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
gabrown2
Apr 11, 2015 08:22 PM
