08 Coupe Manual Transmission AC issue
Old Jun 27, 2012
sixout's Avatar
sixout is an unknown quantity at this point
Ok, I started having this problem back in February.
The ac works fine sometimes. Other times, it'll just stop blowing cold air. It'll keep blowing air, but it'll be hot. First instinct is that it needs a charge. Nope, it's full. No room for any more. It's not a relay because it's still blowing.
Honda wants to charge me 115 to just look at the car, and are estimating it'll be roughly 1800 to 2500 to fix the problem. I'm just wondering if anyone knows if it could be anything fixable on my own?
It works sometimes, it'll randomly kick on and start blowing cool air on long drives for a while. Then go back to hot air. Sometimes it'll work for a day, once it went for a whole week then stopped again. I just have no idea what to do.
Help?
Old Jun 27, 2012
Re: 08 Coupe Manual Transmission AC issue
Wrong assumption. False logic.
Get it to quit blowing cold, and then tap on the clutch relay. See what happens.
Old Jun 27, 2012
sixout's Avatar
everyone I've talked to has said that, so I assumed. I know nothing about ac units. I had another person on another forum just mention the clutch as well. I'll have to check this out tomorrow. Thanks!
Old Jun 27, 2012
Read this thread: https://www.civicforums.com/forums/1...nt-engage.html
This person also claimed "and relay is good."
There are several things involved, more than just "a relay". If tapping on it doesn't help, then it's a place to start the diagnosis.
HTH
Old Jun 27, 2012
sixout's Avatar
So I tapped the relay, immediately there was a click, and then cold air started blowing out.
you guys are amazing. I don't know how even the mechanic I took it to said it was an electrical problem and he couldn't fix it.
Old Jun 27, 2012
Lots of people work on cars. Far fewer can solve certain problems and fix them.
Electricity is sorta like the "final frontier" for most mechanics. Electronics is far worse for them, and computers are OMFG RUN AWAY.
It's treated like some kind of black art voodoo, because an easy 85% of the people in this trade have little to no understanding of it.
At my first real wrenching job, the boss called me "Fusebox".
Go to a dealer, buy the updated relay mentioned in that thread: https://www.civicforums.com/forums/1...ml#post4607316
Ask for that part number, do not accept any substitute.
Don't even tell them what it is for, just get that part number.
We keep a few of the updated relays on hand at work.
Updated relay is black and says MITSUBA on top.
It is the exact same relay (location) as the one on the car in that other thread.
HTH
Old Jun 28, 2012
speedy25's Avatar
speedy25 is an unknown quantity at this point
Soooo is this like the main relays in civics of old that went bad when the solder joints cracked? If so a quick resolder will fix it and make it more reliable since the solder we get is better than whatever the factory got!
-SP
Old Jun 28, 2012
Nope.
It's a simple plain relay.
Contacts get pitted.
Replace the damned thing and be done with it.
Old Jun 28, 2012
Here is something else I thought of:
The people in our parts department don't even know about it. (Or can't be bothered to learn about and remember it.)
I have to pick this relay myself.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
pazzmore
Dec 24, 2001 07:39 PM
