Use a Shorter Drive Belt?
Old Jan 24, 2012
DanS's Avatar
DanS is an unknown quantity at this point
The AC compressor in my 2006 Civic is failing. It still works, but it squeaks and does not turn well. Since it's expensive to replace the compressor, I was thinking maybe I could just use a shorter drive belt and bypass the pulley that drives the AC compressor.
Is it possible to buy a shorter drive belt?
Other than not having AC, is there any downside to doing this?
Old Jan 24, 2012
Re: Use a Shorter Drive Belt?
I have yet to see one of these compressors fail in a system that is all original, as of yet.
Yes, you can.
Ask for a serp belt to fit a 06 Civic DX without AC.
(The Autozone site didn't ask if it has AC, but another parts store site did ask. So it might take some trial and error.)
Defogger will be crappy without any AC. Summer will suck. Other than that, no.
Old Jan 25, 2012
DanS's Avatar
The AC compressor clutch failed two years ago, about three days after I had the car in at the dealer for maintenance. I had it replaced by an independent mechanic.
Then last fall I took the car in to Discount Tire to have them put the snow tires on, and the AC compressor started squeaking soon after. The AC and defogger work fine, but my mileage stinks.
Thank you for your advice. I have a very short commute now, so I will probably just get a Civic DX belt as you suggested.
Xuhme
21
Aug 7, 2023 03:40 PM
sharp66
31
Jun 12, 2022 08:45 AM
smmahan
Apr 15, 2015 08:17 PM
dano2005
Apr 14, 2015 01:58 AM
MyCivic
Nov 21, 2001 02:11 PM
