Honda Civic SI Cold Air Intake Problems
Old Nov 30, 2011
VtechFreak's Avatar
VtechFreak is an unknown quantity at this point
Hello there. I have a Honda Civic Si 2010. Recently, I installed a Cold Air Intake into my engine. However, the next day I noticed that my idle rpms where lower than 0.8 and at first gear it would get very close to stalling. Also, I could barely get to 6000 rpms and my top speed was around 90mph. Does anyone know what could be the problem?
Old Dec 1, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Honda Civic SI Cold Air Intake Problems
Is your CEL on? if so then it might be your MAP sensor. Is it an oiled filter? these sometimes are over oiled and get the sensor dirty making your car think something funky, try to clean the sensor and see if that helps.
Old Dec 1, 2011
VtechFreak's Avatar
Thanks Gunner, I might try that out. Either way, I would have to install the cold air intake again because i didnt want to downgrade in performance while I looked for answers so i put in the stock intake. Good thing I didnt pay a relatively large amount of dough for it.
Old Dec 1, 2011
VtechFreak's Avatar
Btw, I am just now getting into the world of cars so whats the CEL sensor?
Old Dec 2, 2011
Gunner's Avatar
Your check engine light. What Intake did you install? I know there are some problems with AEM filters that cause similar issues, its a design problem of some sort. Biggest thing is to make sure you hooked everything up right and have a good seal with everything.
Old Dec 2, 2011
it has to do with the MAF sensor being in the wrong position in the intake system. too close to the filter and the air will be turbulent and give false readings. AEM filters are all dry synthetics and will not cause problems.
Old Dec 2, 2011
Gunner's Avatar
Aye, i meant the intake itself not just the filter..but i did say filter...The AEM intake has a "vane" coupler that should come with it now becuase it is know to cause MAF issus with 8th gen civics
Old Dec 2, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
Its your MAF sensor causing the issues. The problem is the Honda OEM sensor is to sensitive. I have seen this before on the later models. Hondata flash pro will eliminate the problem fairly simple but its not the cheapest way to go.
jessicakaybby
Apr 20, 2015 12:11 PM
Gl3n1234
Apr 18, 2015 01:51 AM
ph0ng
52
Mar 4, 2003 09:15 PM
eXNBP
Dec 9, 2001 12:32 AM
SneakerPimp
Bolt-on Engine Performance
Nov 4, 2001 01:12 PM
