1995 civic alarm wiring
Old Aug 22, 2020
silentz's Avatar
silentz is an unknown quantity at this point
Hi guys, I bought a cheap eBay key-less entry and trying to install it. Well, I ran into a problem where the door wont lock or unlock. Please check my wiring and see if I did it right. I'm using https://www.the12volt.com/installbay...tail/1048.html for wiring colors.
https://imgur.com/a/hrYXPFe
I ran the 12 volt from the battery to the red wire.I ground the black wire to a bolt. Tested red and black with multi-meter and came out 12v.
I connect both brown wires to red/black as shown in picture 3. Parking lights flashes when pressing lock/unlock on the key fob.
I connect white and white/black to green/red and green/white.
I connect the yellow and yellow/black to the 12v wire along with the red wire.
I ground orange and orange/black to the same spot as the black wire.
I followed the procedures to program the key fobs and it works fine. However, when I click lock/unlock on the key fob; the key-less box clicks but the door wont lock or unlock.
All wiring will be solder and electrical tape once everything works.
Please help.
Thanks in advance.
Old Aug 23, 2020
Colin42's Avatar
Re: 1995 civic alarm wiring
Have to ask but does the car have power locks?
Were they all working before you attempted this?
Old Aug 23, 2020
silentz's Avatar
I got this working after fiddling with it for a few hours. Everything wire up the same but for lock and unlock, I got to use the greed/red and green/white wires from the back of the fuse box instead of the front like I did. For anyone doing this cheap ebay keyless entry, use the wires in the back of the fuse box and it will work no problem.
My car is 1995 auto windows/door locks.
Thanks Colin42 for the help.
hardrew_rolly
Mar 11, 2012 11:04 PM
hardrew_rolly
Electrical DIY
17
Jan 21, 2012 03:48 PM
kryal
Dec 12, 2010 06:41 PM
Vetteburton
Oct 6, 2006 02:33 PM
Manofsteel
Dec 27, 2002 03:05 PM
