ECU problems. HELP
Old Sep 10, 2016
Mahlon's Avatar
Mahlon is an unknown quantity at this point
ECU problems. HELP
Hi guys new here so hopefully I'm in the right spot. I have a 01 Honda civic 1.7L. Had a broken bolt in alternator which fried the ECU. My question is I can't find the exact part number for my ecu. I found one that is the exact computer just not the exact part number. My understanding is it will still work but since it isn't the same part number instead of just getting it reprogrammed I now have to have a new key made?. My question is I just seen a post that said if I buy a ecu that comes with the ignition and key I can just switch both and not have to have it reprogrammed at all. Is that true. Any help would be great. Hope I'm making sense lol.
Old Sep 11, 2016
Re: ECU problems. HELP
ANY replacement ecm/pcm, new or used, has to be electronically "mated" to the keys and immobilizer system in your car.
If you get a used pcm along with the immobilizer and keys it was mated to, it will run without dealer programming.. The ignition switch and steering column lock assembly contains the immobilizer control unit.
Downside: Multiple keys needed to open the door and start the engine, and if you ever lose the ignition key you're kinda screwed as the dealership can't cut a key by code for a lock that did not originally come on the car.
ezone
May 6, 2021 07:41 AM
nophilangie
Mar 27, 2016 09:40 AM
Nalmonte
Mar 22, 2016 11:31 PM
WEG
Mar 22, 2016 11:29 PM
Theodorekaminsk
Mar 15, 2016 12:35 AM
