Help with alarm. 2005 civic sport
Rep Power: 0 Help with alarm. 2005 civic sport
Hi there my civics battery died a couple of days ago and every time I try to charge it my alarm goes off. My key phob doesn't seem to be unlock the car to disengage the alarm. Any one had similar problems or even better a solution?
Re: Help with alarm. 2005 civic sport
Stock fob and alarm in the car, not aftermarket?
Connect battery with the doors closed.
Let alarm go off if the fob doesn't work.
Unlock drivers door with key.
Get in and turn the ignition on with the key.
Rep Power: 0 Re: Help with alarm. 2005 civic sport
Thanks I'll try disconnecting battery. Yeah stock fob stock alarm. I've tried using key to lock and unlock and tried the transmission. But as the battery is dead it won't start up. Does the engine need to start up or is turning key to second position enough?
Of course you need a decent battery
Check your owners manual for more alarm instructions
My theory:
If the battery dies while the car was locked and alarm armed, it will go go nuts when it "wakes up" (powers up using a charger or jumper cables) and realizes the door is unlocked and open. You have to get it powered up long enough to get it disarmed before it will shut up.
You could pull the horn relay out so it isn't so damn annoying LOL
My theory:
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
DC5@EM2
Bolt-on Engine Performance
12-04-2001 07:53 PM
