DRL problem please help!
Old Sep 11, 2015
shaejb15's Avatar
shaejb15 is an unknown quantity at this point
Hi everyone,
So recently I swapped out both of my headlights for LED's. As soon as I switched the bulbs my driver's side light is not staying on during the day. When the car starts and I put my parking break down, it flashes quickly but doesn't stay on, the passenger side one does. And remember, this is right after I installed the headlights.
Is anyone able to give me a list of things that may be causing this sudden issue? I have talked to my honda dealership and they have no idea, they say no problem with the module.
Thanks
Old Sep 11, 2015
CraigW's Avatar
Re: DRL problem please help!
Swap positions, then see if the same led still flashes.
Old Sep 11, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Year make and model please. Which country of origin. These facts change how the car is wired, which allows people to better inform you of possible solutions.
I will just give you a link to a very well informed guru of all knowledge involving automotive lighting. Anything you want to know about how headlight work or don't work can be found there. He really is an expert and a "car guy." I personally have issues with putting led's in headlight housings.
www.danielsternlighting.com
Old Sep 11, 2015
shaejb15's Avatar
Thanks for the info.
It is a 2002 civic coupe lx - canada
Old Sep 11, 2015
If the Canadian car DRL unit connects 2 lights in series, both lights run at half of system voltage (half voltage = half brightness).
Are the LED lights designed to work at half of system voltage?
Old Sep 11, 2015
shaejb15's Avatar
That sounds about right. The lights I'd say is half on compared to the headlights being on.
Old Sep 11, 2015
I'm asking if the LED lights you got are capable of operating at 6-7 volts.
I'm guessing that's damn close to their threshold voltage, so they probably cannot be reliably lit at that low of a voltage.
"Similar to standard diodes, nothing happens in an LED until the threshold voltage of (?) is applied across the LED."
A plain LED might require a minimum of 2.7v, but an array connected in series to run on 12-14v should have a much higher threshold voltage.
Reinstall your original headlight bulbs and verify they do work correctly, to be sure the car is not the problem here.
Old Sep 11, 2015
shaejb15's Avatar
I did. Same thing happening. Pretty sure it's something in the car.
I did. Same thing happening. Pretty sure something burned out in the car, i'm not sure. Thats what I'm asking, if anyone knows what could go suddenly wrong after installing Led's. Thanks
Old Sep 11, 2015
Check and wiggle bulb connectors (keep the lights ON so you can see any change, even a flicker)
Tap on the DRL control unit and see if anything happens with the lights (keep the lights ON so you can see any change, even a flicker)
Pull out the DRL control unit and resolder everything you can on the circuit board. The relay connections tend to crack their solder joints causing loss of connection.
If you don't want guesses, get a wiring diagram and test light or voltmeter and figure out where the real fault is.
I'm in the US, we don't have DRL on cars that old but I've had to fix a few, resolder did the trick for me.
Old Sep 11, 2015
shaejb15's Avatar
If I tap the control unit and it does flicker or flash, what does that mean? I did get the board resoldered already.
Thanks for the info
I did already get the board resoldered, no luck. If i do tap the control unit and it does flash, what does that mean?
Old Sep 11, 2015
Thanks for the info
Uhhh....
All it would mean is you are near a poor connection and you are probably on the right track.
The vibration from tapping would (hopefully) cause a poor connection to make/break contact, thus lights flicker or do something different (flicker, work, or quit).
"Poor connection" does not necessarily mean wires. It could be internal in the control unit or whatever you are tapping on.
Sleuth it out.
Old Sep 11, 2015
shaejb15's Avatar
Uhhh....
Sleuth it out.
Understood. Thanks. Also forgot to mention, when I was unplugging the headlight that doesnt work the one on the other side was flickering (car was on) any hints?
Old Sep 11, 2015
Depends, and your observation may or may not be meaningful without more info and observation.
Could just be due to voltage spike for all I know.
What were the lights set on? Headlights? DRLs? Low beam? High beam?
For that matter,
What still works correctly?
Which does not work correctly?
How about if you switch back to the correct bulbs, what all does and does not work?
Swap bulbs side to side, does the problem move with the bulbs or not?
Old Sep 12, 2015
shaejb15's Avatar
What were the lights set on? Headlights? DRLs? Low beam? High beams
For that matter,
I put the old bulb in and tried it with no luck on the DRL. And I'm pretty sure the headlights were on Drl. I'll be doing some futhur testing next week. Thanks for your help
eorlando1
May 17, 2015 11:16 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
