2003 Honda Headlights wont shut off?
Old Jun 9, 2015
ericaagarcia's Avatar
ericaagarcia is an unknown quantity at this point
A couple nights ago my both of my headlights shut off and would not turn back on. we tried to switch the bulb, and that didn't work. my high beams work perfectly fine though. I took it to a mechanic and he switched out the relay, and now my headlights wont shut off. the switch for my lights isn't working, but I am still able to turn on and off my high beams, and all my other lights work, but my low beams are still on. please help me out!
Old Jun 9, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: 2003 Honda Headlights wont shut off?
you could pull the relay out so it doesn't kill the battery in the mean time. I'm assuming he check the fuses for the headlights as well. Maybe something is wrong with the switch itself??? I would think if the relay is functional and in-place then the switch is worn out.
Old Jun 9, 2015
yes he checked the fuses as well! he's switching the switch right now so I'll let you know! thanks!
Old Jun 9, 2015
Have your mechanic UNDO whatever he did (LOL)
See your Honda dealer ASAP, there's a recall for the headlight problem.
They need to check the VIN first.
Some people have reported problems after the recall due to shoddy work, so be aware....
Old Jun 9, 2015
I went to Honda & they told me my car wasn't part of the recall for the headlights.
Old Jun 9, 2015
OK, even if it's not under the recall there's a good possibility that it's been affected the same way.
It's probably worth having a look in the headlight switch connector for evidence of terminal overheating on the wire that runs the low beams.
The headlight switch and that connector is where I probably would have started the diagnosis, instead of just making them stay on all the time.
Old Jun 10, 2015
they turned me away at Honda when I brought up the recall with them :/ but thanks for the other info, I'm going back to my mechanic tomorrow, and I'll have him look into that!!
Old Jun 10, 2015
CraigW's Avatar
Recall is 01s and early 02s.
Pretty sure the schematics are on this site, if he needs them.
Old Jun 10, 2015
It applies to SOME 2003 Civics as well, if the VIN status report lists the recall.
Old Jun 11, 2015
CraigW's Avatar
^^^ Did not know.
Staying ON seems a bit odd I must say.
Old Jun 11, 2015
thanks for all the help! they are barely going to switch the switch itself today & I will keep everyone informed if that in case was the problem!
docmartin14
Jul 30, 2015 11:26 AM
BootyDo
May 7, 2015 04:46 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
Bartkat
20
Feb 19, 2002 01:29 PM
