Cd Player Stopped Working
Old Apr 27, 2014
Ghettochild2600's Avatar
Ghettochild2600 is an unknown quantity at this point
I have a Pioneer DEH-X3500UI http://www.pioneerelectronics.com/PU...rs/DEH-X3500UI I turned on the car and everything was working fine until I turned up the volume and suddenly the unit shuts off. Checked all fuses and they are fine. Wondering what caused this to happen and how/if it can be fixed. Thanks.
Old Apr 27, 2014
Re: Cd Player Stopped Working
Dead to the world, no lights or anything?
If you used the stock wiring, check
fuse 23 in the dash and
fuse 32 in the engine compartment.
Check the fuse either in the back of the radio or in its wiring, if equipped.
Disconnect the battery for several minutes, as a reboot?
Old Apr 28, 2014
Checked the fuses and rewired the entire unit. Used a multimeter to test for power output to the stereo and I'm getting a steady 12.5v. Doesn't make any sense to me
Old Apr 28, 2014
Stock 99's Avatar
So what? No power / no display at all?
Is the wiring cut and spliced into the car or was a conversion wiring harness used?
There should be 2x12v in 1 for constant power, 1 for accessory power. Check and make sure there's a proper ground connection.
Old Apr 28, 2014
Edit: Apparently I overlooked a fuse under the hood. 5A fuse blown where there should be a 7.5A fuse... Works now. Name:  IMG_20140428_121826_zps4wus8bxi.jpg
Size:  126.9 KB Second fuse to the right on top.
Good ground connection and fuses. Completely dead stereo. Checked the constant 12v and it's not getting power, only when switched on. I had a 64GB USB flash drive plugged in at the time, but I don't think that contributes to the issue.
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
SSMatey
Apr 13, 2015 06:09 PM
CivicLX2001
Nov 16, 2001 06:33 PM
