Fog Lights
Old Aug 20, 2012
usvpn's Avatar
usvpn is an unknown quantity at this point
Fog Lights
Hi,
I bought a set of fug lights for my Civic Sedan 2009 4DR (not genuine)
I want wire them directly to the small parking lights!
But each one is 55 watts and I am afraid there will be extra pressure on fuse or other parts!
I need them to be turned on with small parking lights and don't need a separate switch!
Please advise
Old Aug 20, 2012
GolNat's Avatar
Prelude Owner
Re: Fog Lights
You need to wire the parking lights to a relay and run your fog lights off of the relay.
Old Aug 20, 2012
usvpn's Avatar
Re: Fog Lights
So use the relay, but where to get the power from? Directly from battery?
Old Aug 21, 2012
GolNat's Avatar
Prelude Owner
Re: Fog Lights
Correct. Battery positive to pin 30. Fog light positive to pin 87. Parking light positive to pin 85 and ground to 86.
Old Aug 21, 2012
usvpn's Avatar
Re: Fog Lights
What if I directly connect the fog lights to the parking lights and increase the parking lights fuse from 7.5A to 15A for example? This way any problem happens?
Old Aug 21, 2012
GolNat's Avatar
Prelude Owner
Re: Fog Lights
No, that would not be a good idea. It's best to use relays to reduce current draw because in addition to reducing current draw they also isolate things from each other. You could end up frying something in the ECU or multiplex unit.
Exterior
Nov 28, 2025 05:23 PM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
