ALL Power windows will not work NEED HELP
hello i have a 1998 Acura el all the power windows will not work if you push the drivers window switch you hear a buzzing sound coming from the switch and you also see the Heated mirrors light flash every-time you push the switch Need help
Re: ALL Power windows will not work NEED HELP
1)You've tried all 4 buttons on the driver's door AND each window switch on the other 3 passenger doors? NONE OF THEM work?
2)You checked the fuses? All of them?
3)You checked the electrical connection between the door and the rest of the car for frayed/disconnected wires?
4)Does everything else work?
They like to break the wiring in the jamb area.
FIGURED IT OUT!!!!!! Turns out it was the GROUND wire. I cut it just where it came into the door, and grounded it to a bolt on the door. All the windows as well the driver side heated mirror works now. Thank you all for your troubleshooting help.
Congratulations! Feels good, doesn't it? :-)
trellex
May 24, 2015 04:39 PM
got2kids
May 9, 2015 06:45 PM
ORskier
May 3, 2015 12:54 PM
