Passenger Power Window Switch
Old Nov 14, 2011
RV Tech's Avatar
RV Tech is an unknown quantity at this point
2004 Honda Civic Coupe EX -
Passenger power window switch does not operate window.
Passenger window works fine from drivers door master switch.
Does it have to be the passenger door switch or could it be the master switch?
I don't know what the wire diagram and colors are so I can't troubleshoot it very well.
All help is appreciated. - Thanks
Old Nov 14, 2011
Re: Passenger Power Window Switch
passenger switch is proly broken. if the driver switch did not work either, then its possible the passenger switch is fine, since you need the driver side switches working and connected for the other window switches to work. but since yours works, its passenger switch gone bad.
Old Nov 14, 2011
RV Tech's Avatar
Thank you
Old Nov 14, 2011
CraigW's Avatar
You could do a quick voltage check of the GRN/BLK wire at the passenger switch. With key at II it should have voltage present. If you have voltage then likely the passenger switch is the problem.
Old Nov 14, 2011
RV Tech's Avatar
Yes, I have voltage there.
Ordered a switch, see how it goes. - Thank you
Old Nov 15, 2011
CraigW's Avatar
Old Nov 24, 2011
RV Tech's Avatar
The new passenger switch has solved the problem. Thanks for the input! - Ron
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
werdnahall
May 17, 2015 11:37 AM
Cypher
Dec 15, 2001 07:25 PM
mwwhonda
Nov 7, 2001 07:24 PM
