Headlight projector problem need help!
Old Oct 1, 2009
duytvo's Avatar
duytvo is an unknown quantity at this point
I just installed my new projector lights with HIDs installed. My problem is that the passenger side HIDs work, but the driver side doesnt turn on! I hooked the plug back into my old H4 bulb, its sometimes comes on, i was hoping it wasnt the newly bought HID bulb, could there be something else that is wrong?
Old Oct 1, 2009
Re: Headlight projector problem need help!
stock wire harness does not support the high amp draw of hids. too thin and not enough power flow. you need an upgrade relay harness with thicker wire. hopefully you didnt permanently damage the oem harness.
Old Oct 1, 2009
electric130's Avatar
exactly what gear said. my Matsushita ballasts (nissan maxima) pull ~10A on startup. the pnp kit i got off ebay for my fogs says the max current inrush on startup is 20A. so x's that by 2. no way the stock wires can handle 40A. i have a relay harness with 2-30A fuses and 2-30A relays, one set for each ballast, and i'm running 12ga wire. to the ballasts.
Old Oct 1, 2009
duytvo's Avatar
what would be a good harness to get? and is that why only the passenger side works?
Old Oct 2, 2009
yeah not enough power to run both sides at the same time. check ebay for harness
Old Oct 5, 2009
duytvo's Avatar
i found out what the promblem was they just mislabeled the positive and negative on the ballast! thanks for the help though!
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
shaejb15
Apr 26, 2015 07:44 PM
Hondasport01
Dec 17, 2001 01:53 PM
