front indicator bulb
Old Aug 5, 2009
lezmtaylor's Avatar
lezmtaylor is an unknown quantity at this point
How do I change a front indicator bulb on a Y reg 5 door Civic ? please.
Regards,
Lez
Old Aug 5, 2009
CraigW's Avatar
Re: front indicator bulb
Your owners manual should have the procedure.
You may have to remove the inner fender plastic and reach up inside to access socket & bulb.
Old Aug 5, 2009
unTuned's Avatar
i dont understand what you mean by Y, reg, or a 5 door civic.
but if its a sedan, you will have to turn your tires completely AWAY from the side youre working on, and undo a couple of those little clips on the inside of the wheel well. once you do that you can pull the plastic cover back, reach inside and unclip the bulb from the harness, and twist the bulb out. just twist the new one in, clip the harness, and close the fender flap back up.
Old Aug 6, 2009
electric130's Avatar
yep, go through the wheel well.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
MamaBear2015
Jun 11, 2015 07:33 PM
Lopes101
Jun 7, 2015 08:04 PM
bsmiley
Apr 27, 2015 01:27 PM
