Amp issue
Old May 26, 2009
Amazing's Avatar
Amazing is an unknown quantity at this point
Exclamation Amp issue
hot days my amp likes to cut it and out, the subs just go on when they want, my system is in the trunk and dont know what to do, i am not going through fuses but the thing does it in hot weather, any idea what to de
running 2 10" rockford subs on a JL e1200
Old May 26, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: Amp issue
Put in rubber spacers under your amp and then run computer fans to cool it off from underneath. Im guessing it is going into protection mode?
Old May 27, 2009
electric130's Avatar
Re: Amp issue
where is the gain set at? if you have it all the way up, like BJ said, it's probably going into protection mode as it's being worked too hard. you might need a new amp.
Old May 27, 2009
BJanzen's Avatar
Re: Amp issue
Good point, didnt even think about the gain being set to high. Just to inform anyone that reads this, when you tune an amp you do not want the amps gain to be all the way up. The distortion will be worse at max gain. I highly recommend setting it at 3/4 (this is my opinion/recommendation).
Old May 28, 2009
Amazing's Avatar
Re: Amp issue
i am pretty sure it is at three quarters not to high
frequency at 120
Old May 29, 2009
whitealexander's Avatar
whitealexander is an unknown quantity at this point
Re: Amp issue
thanks for the tip, i lowered my gain..
Old Jun 9, 2009
bachlava7's Avatar
bachlava7 is an unknown quantity at this point
Re: Amp issue
A question, do you have a capacitor in your system? I know you said this happens usually on hot days, but a capacitor might help your subs and amp run more smoothly when the power is drained by peaks in the music (which can lead to the subs cutting in and out).
Old Jun 9, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Amp issue
How's your amplifier mounted? It needs proper ventilation because if it overheats it'll just shut itself off to keep from burning your car down.
Your Question: How do I stop my amplifier from turning off?
What you should be asking: How do I ensure my amplifier is kept cool?
Old Jun 9, 2009
DeX's Avatar
DeX
Canadian, Eh!
Re: Amp issue
roverben
Jan 21, 2019 05:16 PM
jackoncruzpr
May 24, 2015 12:24 AM
WLakers
May 4, 2015 06:23 PM
NeonNights
Jan 23, 2002 09:50 AM
SLeePeR012
Jan 7, 2002 12:24 AM
