El Gauges Dim
Old May 17, 2008
cdanimatrix's Avatar
cdanimatrix is an unknown quantity at this point
Exclamation El Gauges Dim
I installed reverse gauges about two months ago and last night while driving they became dim. The brightness control doesnt work and it only becomes bright when turned on then dim down again..?!
Old May 17, 2008
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura aboutONE7thREBUILT has a spectacular aura about
Re: El Gauges Dim
Wire backwards a lot, do you?
Old May 17, 2008
Re: El Gauges Dim
all i did was tap into the power and ground..wat would be backwards?
Old May 18, 2008
Re: El Gauges Dim
did you choose a good ground? the shop that did mine put it somewhere stupid so they would dim and flicker all the time. finally i moved the ground wire to an actual ground on the car body (no painted surfaces) and it worked fine.
Old May 23, 2008
Thumbs down Re: El Gauges Dim
I redid all wiring and moved the ground to the screw holding the dash panel. Everything worked fine again for a day then went back to the same thing when i turned it on the day after.
Old May 23, 2008
Re: El Gauges Dim
thats not a proper ground!! its where the shop put mine when they did it and caused the flickering. you have to move it so its directly touching the metal car body. sand off the paint too before screwing it on.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
