help...sound system and battery problem!
Old Apr 1, 2008
tuan25000's Avatar
tuan25000 is an unknown quantity at this point
hey guys, i need your help please.
im having a problem with my battery dying. Recently, i jus hooked up my sub and amp (running about 500 watts). I also have a 4way amp hooked up for the 4 speakers which was there before. Everything worked fine at first, no problem at all...no dimming of headlights,etc.
However, after leaving the car overnight, for some reason the battery gets drained. I tried disconnecting the fuse for the sub and the problem was solved, so i'm pretty sure the sub is causing the problem. does anyone know what the potential problem could be? is it the alternator? i should also mention that there has been engine noises coming from my speakers for awhile now.
thanks.
Old Apr 1, 2008
hvc's Avatar
hvc
hvc is an unknown quantity at this point
Re: help...sound system and battery problem!
I believe it's hooked up wrong, and your amp/sub is drawing power all the time. Did you do the installation yourself?
Old Apr 1, 2008
tuan25000's Avatar
no, it was installed by futureshop about a year ago and it worked fine until now. im sure i have the wires hooked up correctly on the amp though. any idea what could be wrong?
Old Apr 2, 2008
hvc's Avatar
hvc
i'm sure it could be lots of things.
it's possible some of the wires moved around over time, or it could be your amp.
Take it in to futureshop, have them have a look (it's free if they installed it), if not don't take it there.
Old Apr 2, 2008
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
check your remote wire on the amp and head unit. usually a little blue wire. what the head unit uses to tell it to turn on and off
Old Apr 2, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
It's hooked up wrong for sure. Check the red, white and black wires to see where your constant, switched and ground wires are connected. I'm guessing they hooked your amp to the cigarette lighter which in most cases is only powered when the car is on. But rarely you'll find a manufacturer that develops a vehicle where the lighter is powered constantly.
Old Apr 2, 2008
twiztedD17A1's Avatar
twiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nice
Your alternator is bad therefor its reversed polarity draining you battery, or your battery is toast. Take them to your local pep boys or advanced auto and get them checked its free to check them.
Old Apr 3, 2008
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
hmmm, i would doubt taht the diodes are messed up in the alternator, but if it JUST happened, then it could be a possibility. If the check is free, might as well. Other than that, either bring it to future shop, or check the wiring yourself.
Old Apr 5, 2008
tuan25000's Avatar
thanks for the help guys but i figured out the problem... it was because i didnt turn the music (deck) off before turning off the car... and somehow that drained my battery!
Old Apr 6, 2008
DeX's Avatar
DeX
Canadian, Eh!
Exactly what I said. You shouldn't have to do this, your switched wire should take care of it for you. So you've got the wiring hooked up wrong.
Old Apr 8, 2008
hvc's Avatar
hvc
Exactly what me and DeX said. It's wired wrong. If you take it back to future shop, they'll fix it for free. I believe they have a (much needed) lifetime warranty with their (crappy) installations.
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
Youshoe
May 22, 2015 09:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
