amp fried?
Old Nov 17, 2007
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
amp fried?
can anyone answer this question?
what occurs when an amp gets fried?
the fuse off the battery blew and my amp shut off......for a split second my amp was smoking a little bit...I could smell it.....does this mean the amp got fried or can I jsut replace the fuse and have her power back up?....what are the chances it is still ok?.....the fuse should have blown (which it did)
Old Nov 17, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: amp fried?
Many different things can happen when an amp "fries". In my opinion the most common issue is going to be over-current through a transistor which will destroy it. However, pretty much any other component internal to the amp could either stop working itself or become blown. Sometimes it can be something as simple as swapping out one bad component for another.
I would pull the amp from the car, and test it on a bench with a 12V supply of some sort. If it does start smoking on the bench she's probably toast.
Old Nov 17, 2007
jrock's Avatar
Re: amp fried?
I just got back from best buy and he said it is done....I am going to try and send itout to rockford to see if they can fix it
Old Nov 17, 2007
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
Re: amp fried?
ouch.. sorry to hear that man.. i had a rockford and my wires got crossed and i fried my amp as well. you didn't get warranty through bestbuy? (assuming you got the amp there) hope the repair doesn't cost more than getting a replacement.
Old Nov 17, 2007
jrock's Avatar
Re: amp fried?
of course I am kicking my *** now cause I didnt get the warranty.....what did you end up doing?
Old Nov 17, 2007
aznprid214's Avatar
Re: amp fried?
well i actually only fried one channel.. so i just gave it to a friend to power his sub. one side was enough to push a sub so he's just doing that.
you said fuse on battery blew? the inline fuse? is there not a fuse on the amp itself? i know i have a fuse from my battery into my amp, and 2 fuses on my amp so i should be ok (hopefully)
Old Nov 17, 2007
jrock's Avatar
Re: amp fried?
the tube fuse off the pos on the battery I jus replaced....the 2 30amps on the amp did not blow...they are fine...
I want to know if this thing can be repaired before I go and invest in another expensive piece of equipment
Old Nov 17, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: amp fried?
if you seen a burst of white smoke.....chance are you popped the MOSfets.
Toasted amp.....
Old Nov 18, 2007
electric130's Avatar
Re: amp fried?
anything can be repaired. it just depends on how much you want to pay for the repair.
Old Nov 18, 2007
jrock's Avatar
Re: amp fried?
I think I am going to try and send it to this company http://www.audiotekx.com/index.html
anyone have any experience with them?
or can someone recommend a nice amp for 1 single 12" 1222d type r dual 2 ohm dvc
Old Nov 20, 2007
jamis33's Avatar
You Stay Classy, San Diego
Re: amp fried?
JL 500/1 all the way. Probably the greatest amp ever made for multi use. Or like a alpine F-450. Its less expensive but if it was me i'd spend the extra and buy jl. Ive had 4 sets of subs and after gettin my JL's i'd never own anything else.
Old Nov 21, 2007
jrock's Avatar
Re: amp fried?
well I opted to just send out my amp to be repaired by that company....being that the most it will cost me is 70-90 I figured why not!
Old Nov 21, 2007
jamis33's Avatar
Re: amp fried?
good idea but im gonna let this be a warning to a few people. This is not the first time ive heard of a rockford amp doing this. I know a few guys that their rockford amps just stop working one day. They blow easily. I dont know why but they do. Just thought I should put it out there that they aren't the greatest amps out there and I dont think it was all ur fault that it broke. It was probably a manufacturer's flaw in design.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
