tweeters
Old Nov 6, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
tweeters
For wiring tweeters, can i just splice into my front door speakers and run a bass blocker in the line? Im thinking about adding some tweeters in the front doors and wanted to find the best way to do it. thanks
Old Nov 6, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: tweeters
yea...you can simply splice into the terminals however make sure you use a cap on them otherwise youll cook em. You dont want full range running through them.
Old Nov 6, 2007
mike21190's Avatar
mike21190 is an unknown quantity at this point
Re: tweeters
i'd get crossovers to protect them
Old Nov 6, 2007
greeen01civic4d's Avatar
Re: tweeters
good advice, but its cheaper to get tweeters with crossovers either built in(rare) or that come with them
Old Nov 6, 2007
mike21190's Avatar
Re: tweeters
yea ones that come with them would be better
Old Nov 6, 2007
Re: tweeters
oh, and bass blockers suck, its a cheap way of mocking a crossover, dont do it, ull waste ur speakers quick
Old Nov 6, 2007
mike21190's Avatar
Re: tweeters
you might want to also think about components (if you don't have new speakers) comes with the speaker, tweeters and crossovers
Old Nov 6, 2007
Re: tweeters
good call^^^ i just bought memphis audio components for about 250, gonna install them this weekend, but i gotta mock up some spacers
Old Nov 6, 2007
FGCOUPE's Avatar
Re: tweeters
it all depends?
do you have a pair of tweeters on hand you want to use or...
are you considering on buying a set?
if you have them on hand and cannot afford and/or dont want to spend the money on a crossover unit, then a set of capacitors will do the trick inline on the POS+ wire spliced into the speakers.
If you are buying a set...yea, in most cases they come with a crossover included.
i think to install them they say to keep them around 6" away from the speakers for sound quality?
Old Nov 6, 2007
mike21190's Avatar
Re: tweeters
i have JBL 5 1/4 components, i got them for $150 and there great
Old Nov 7, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: tweeters
go with the components. Adding tweeters to your stock speakers is like dropping your car with nice springs without changing your struts. Sure you can do it, but its not the best idea. Check around ebay or even on here and get a component set. You will be ALOT happier.
Old Nov 7, 2007
chawski's Avatar
Re: tweeters
wow thanks for all the advice guys. i currently have Alpine R speakers in the doors and kinda wanted to play with the idea of doing some tweeters. All in all, they sound pretty awesome as is. ill take a look for some with a built in xover. my door speakers are powered by an alpine 50(ish)x4 channel. is there any risk of blowing them getting that much power or is that usually fine for most tweeters?
Old Nov 8, 2007
electric130's Avatar
Re: tweeters
got infinity reference CS6010 components from crutchfield for $100 new.
Old Nov 9, 2007
chawski's Avatar
Re: tweeters
how do you think those compare to the alpines? i kinda wanna keep the alpines, mainly bc i have the service plan from worst buy with a few years left on it and quite honestly, they sound great. so im thinkin my easiest route will be to run a tweeter off my front speaker line with a xover in line. that sound about right?
Old Nov 9, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: tweeters
I have personally heard both the Alpine and the Infinity, and me personally, I would stick to the Alpines. The infinitys have a much more "tinny" sound to them with not much mid or low. The alpines have a much more "full" rich sound to them.
Wow that sounded lame, but you get the idea.
Old Nov 9, 2007
Re: tweeters
LOL!!!! for $100 though, my infiniti components sound pretty good.
ZoSoIV
Sep 17, 2015 07:17 PM
Jeffdp
Aug 5, 2015 11:38 AM
STang57
Aug 2, 2002 07:59 PM
TroyA
Jul 7, 2002 10:18 PM
