amp protection problem. HELP!
Old Jun 13, 2007
Hippiboy's Avatar
Hippiboy is an unknown quantity at this point
Lately i noticed that my amp will temporarely shut off when I turn up the volume. Then it will turn right back on. I also noticed that my protection light goes on when the amp turns off. Anyone know what is wrong or how i can fix this?
Right now i have a 1000 watt kicker amp with a 12 in L7 solobaric
Thanks
Old Jun 13, 2007
Stearic's Avatar
Stearic is an unknown quantity at this point
Re: amp protection problem. HELP!
You might have the gain on the amp turned up to much. I'd say try turning it down a bit and see how that works.
Old Jun 13, 2007
Hippiboy's Avatar
i did turn it down. It is only set at the half way. I never had this problem when i first installed the system. I just dont get it....
Old Jun 13, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Maybe need to upgrade the amp's connection to ground. Also might want to check the speaker's resistance make sure both voice coils are alright if it's a DVC.
Old Jun 14, 2007
electric130's Avatar
what size wires are you running on the amp power, amp ground, and battery to chassis ground?
Old Jun 14, 2007
Hippiboy's Avatar
im running 4 guage for the power and the ground. and 12 guage for the speaker.
Old Jun 14, 2007
what about the ground cable on the battery? stock or upgraded?
Old Jun 19, 2007
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I would first double check your power and ground connections, as well as the ones on the battery.. then as Chris was saying, meter your voice coils.. If you have a voice coil that's lower than two or four ohms (other than perhaps a .4 ohm +/- tolerance) that's automatically forcing your amp into protection so you don't fry the amp. What makes me think this is because you posted that it only happens when you turn it up.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
