wires/pins for keyless entry please?
Old Apr 24, 2007
jnash's Avatar
jnash is an unknown quantity at this point
I have a 01 civic with electric door locks but no keyless entry. However, I have programmable remotes and the in-dash receiver unit from an EX for the keyless entry to hook-up. Can someone please tell me where the following 4 wires (12 volt always on, 12 volt switched, data line, and ground) fit on the 5 pin receiver unit? It should be easy for someone to help me.
Unplug your unit located behind the cigarette lighter, and measure the voltage of the four wires going to the unit at the plug on the cable that plugs into it. One will be always 12 volts, 12 volts switched (with the ignition key), and ground which can then be measured with an ohm meter to the car. The remaining pin must be the data cable.
Therefore: what wire goes to what Keyless unit pin? 1,2,3,4,5) One of the pins on the keyless receiver is unused.
wire 12 volt on
wire 12 volt switched
wire data
wire ground
Thanks so much!
Old Apr 24, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: wires/pins for keyless entry please?
1 ground
2 data
3 ignition
4 unused
5 constant
Old Apr 24, 2007
jnash's Avatar
thanks Chris!
Old Apr 25, 2007
electric130's Avatar
rep would be appropriate if not done already.
Old Apr 26, 2007
jnash's Avatar
what do you mean by Rep?
Old Apr 28, 2007
see the little green box like this under "donate" that's a user's rep level. to add to thier rep if they've helped you, click on the little scale and select approve. write a comment on how they helped or thanking them or whatever. your name will automatically appear with the comment, so if you negative rep someone, they'll know it was you.
Old Apr 28, 2007
jnash's Avatar
rep done, thank you for explaining it to me
Old Apr 28, 2007
no prob glad to help.
h4ldol
Apr 24, 2017 08:16 PM
Ziggy1999
Oct 15, 2015 07:56 PM
Donahue
Sep 8, 2015 09:00 AM
JetsterDajet
Aug 16, 2015 01:56 PM
henrytn
Aug 11, 2015 10:01 PM
