2 10's with 1 amp for each?
Old Mar 29, 2007
blinknfgkicks's Avatar
blinknfgkicks will become famous soon enoughblinknfgkicks will become famous soon enough
will it soud "uneven" if i use 1 mono amp for each of my 2 10's?
Old Mar 29, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Re: 2 10's with 1 amp for each?
It all depends on the setup. Are you going to be using the same exact amp and the same exact subwoofers? And if you are going to run two amps are you going to adjust the settings exactly the same? If you answered YES to these questions, then NO it won't sound "uneven".
Old Mar 29, 2007
ok thanks for the fast answer
Old Mar 30, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
You will also have to daisy chain the amps if possible so they will be using the same audio signal...in other words, dont connect one to the "front" rca outputs on your headunit and one to the "rear" rca outs, unless you are running everything perfectly balanced. It helps if your amps have an rca out on them and are able to daisy chain.
Old Mar 30, 2007
they dont have an output
but what if i use y-cabels to split the rca's?
Old Mar 30, 2007
JMUCivic03's Avatar
Does your headunit only have 1 output? I mean, I guess you could use y cables, but you run the chance of picking up interference (more connections usually equals more of a chance for signal degredation/loss). Do you really need to amp each 10 with its own power source? People tend to think they need to throw massive amounts of power at subs when they really need only just a little. What exactly are you running (subs and amps)?
Old Mar 30, 2007
i have two 10 in MTX msz1004's Specs- http://reviews.cnet.com/MTX_MZS1004_...9.html?tag=nav
and i can get a good deal on two MTX ta2301 amps Specs- http://www.onlinecarstereo.com/CarAu...roductID=15172
Old Mar 30, 2007
or should i just get the mtx ta7402?
http://www.onlinecarstereo.com/CarAu...roductID=15182
Old Mar 30, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
go with the two channel... the MTX TA7402... it's more bang for you buck... and it makes wiring a whole lot easier... if you get both the amps then you have to get a wiring kit for the two amps with distributors and more wiring... making it more of a pain in the *** than you want.. and from the looks of it the mono channel amp pushes a really good amount of power on it's own so you might not even need all the power... 300 RMS max... so if you split that between two subs that's 150 RMS and that's more than enough power... unless you plan on replacing your glass windows with plexiglass so they don't shatter... i would say forget the two channel amp and just get the mono channel amp...
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
