Question
Old Feb 19, 2007
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
Question
Can you hook up two amps into one large capacitor? i have one 1000watt and one 360watt amp, so I would need 1.5 farad cap, right?
Old Feb 19, 2007
electric130's Avatar
u can use whatever sized cap you want. caps are just bandaids for needing a bigger alternator though.
Old Feb 19, 2007
MBison's Avatar
^that does not answer my question though.
btw: what's best alternator for 01 civic and where could i get one?
Old Feb 19, 2007
then what is your question if i didn't answer it. i thought i did.
Old Feb 19, 2007
lil_brwn_guy's Avatar
lil_brwn_guy is an unknown quantity at this point
If you wanna know you could use 0.5 Farad's per 1000 watts but current is the real concern, if you used 1.5farad cap it just and no upgrades to alt then you've just added another battery(the cap) for the alternator to charge. do you have a system wiring diagram, cause that would help and make it easier to make adjustments and ideas
Old Feb 19, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
yes, you can. the way i have mine hooked up is the power wire runs straight to the capacitor first THEN split into the two amps using a distrubution block. the amps and cap have their own grounds.
thats one way to wire it. there are other options.
Old Feb 19, 2007
if you are using larger than 4 awg wire you should run both power and ground to the battery, because the body will only give at best the current floe of 4 awg wire, when you use distro blocks use on for power( fused) and one for ground (unfused) use and ground the amps at the same point and run a ground from the deck and ground at the same point, to eliminate noise, there are a tons of ways to wire a system best to plan it out before you go then no issues when you are done ask questions is the best way
Old Feb 19, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yes, you can use one cap with two or more amps.
When done right a cap can be more more than just a 'band-aid'. Besides the voltage stabilization they will allow for short bursts of currents greater than that which the battery/alternator system can provide in a given time.
You can run a power wire into the cap, run separate wires from the cap to the amps. Or run from the cap into a distro block into the amps. You can use a ground disto block or you can ground the amps and cap together. Many options.
So you're saying there is more metal conductor in one ~17ft run of 4AWG than the entire car's body/chassis?!?
Old Feb 19, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
(Alterstart Systems Inc - ) Alterstart Dallas Texas thats the 170amp alt that i have on my car and i beat the hell out of it and its still going strong and at a fair price.
Old Feb 19, 2007
what's the part number? your link is to their home page. found one for $350 on there.....OUCH!
Old Feb 20, 2007
MBison's Avatar
Heres my answer! Thank you! Rep+
Old Feb 20, 2007
MBison's Avatar
wow. quite pricey. thats a truck alternator. does that mean that our civics could practically use an alt from any other vehicle? is there a way to get an aftermarket alternator, lets say, made to 'take lots of beating'?
Old Feb 20, 2007
MBison's Avatar
Which option is best?
Old Feb 20, 2007
MBison's Avatar
Well. I have Pioneer deck DEH-6800 that powers up Profile 1000W 4CH amp thats in the trunk. The amp powers up 4 of my Polk DB6500 (2 in the front, 2 in the back) component speakers w/ crossovers and tweeters. The power cable is 5 gauge that came in the SCOSCHE amp wiring kit that I used to wire this up. Recently I've bought 2 10" JL Audio subs in a box that have Rocksford Fosgate 360a2 amp attached to it. I was told to upgrade the wiring so I bought the Monster Cable 300 series multi amp wiring kit and Monster Cable PRO 4CH rca cables for my components that I'm waiting for to come in the mail. I know I will need a capacitor, and i'm scared to think that i will need to get a different alternator and/or battery.
Old Feb 20, 2007
MBison's Avatar
Old Feb 20, 2007
you need at least 4ga cables, but 2ga would be better. your RF amp can draw over 500w. if the profile is 1000w peak, then you're at 125A current draw which exceeds the limits of 5ga at 118A. 4ga is rated at 135A, and 2ga at 181A. so even with 4ga, you'll be close to the limit. if you go with 2ga kit, you need to upgrade the ground cable on your battery to 2ga as well. i hope that you've already done the Big 3 upgrade also with at least 4ga cable.
Old Feb 20, 2007
MBison's Avatar
wow i did not know about that and i appreciate ur knowledge. i was going to let the 5 gauge wire stay thinking that it does not really matter. i'm going to have to stick with the 4 gauge instead of 2 gauge, since i've already spent $80 on that monster cable kit (at the best deal). thanks so much buit i got more questions. i understand that the negative terminal should be grounded, and that if i use the 4 gauge as power wire, then i will need to ground my battery with a 4 gauge wire as well, right? also, can any wire be considered a 'grounding wire' if it connects to the chassis? Rep+
Old Feb 20, 2007
stock battery ground cable is 5 or 6 ga. you can do the "Big 3" upgrade for $10-12 with 4ga cables. i just did it tonight on my car. with the car at idle at night and the lights on, i would notice that when the RPMs increased, the lights would get brighter. after this upgrade, the lights are bright all the time. also before, lights would dim with bass notes at moderate to high volumes. now, i have to turn the music up real loud (louder than i like to) before the lights will dim. granted, i'm not running the wattage you are, but the point is that the "Big 3" is a simple, cheap, good upgrade. i bought a 4ga 72" battery cable from walmart for ~$5, and 4 - 4ga terminals for ~$5. then i just cut the long cable to the lengths i needed and put the new terminals on. was done in 20 minutes.
so just do the Big 3 upgrade and you won't have to worry about grounds unless you go to 2ga. if you get to that point though, you'd likely need a new alternator.
if i'm understanding you right, then yes. the entire chassis of the car is essentially one big ground "wire." so any wire/cable you bolt to the chassis then becomes part of that big ground "wire." and thanks for the rep.
Old Feb 20, 2007
MBison's Avatar
As of now, my lights do not dim unless i turn my music REALLY loud, then i can see it. i do have an SPC grounding kit that i bought a while back and installed myself, so i might look into that and reconnect few of the grounding wires paying close attention to the battery's neg terminal, because from what i hear, grounding the battery is the most important thing, right?
Old Feb 20, 2007
MBison's Avatar
one more thing. which brand of capacitors should i go with? so far, i'm leaning towards tsunami.
Old Feb 20, 2007
i'm not familiar with that kit. got a link? or what's the details/specs on it. the most important cable is the one from the negative post on the battery to the chassis. since everything is grounded to the chassis, this cable litterally is the only path back to the battery.
Old Feb 20, 2007
i don't know. i don't run a cap so i haven't looked into them a whole bunch. i know that Scosche sells an amp kit with 4ga cables and a .5F cap with digital readout for $80. most other brands will be that much just for the 4ga amp kit without the cap, so i kind of look at it as the cap's free. as far as the power cables go, i've never noticed a difference between Streetwires, Tsunami, Scosche, or RF for performance. copper is copper. they're all flexible, small strand cables, so they're all good IMO.
Old Feb 20, 2007
MBison's Avatar
Oh. My bad, its SCO Grounding kit and heres the link: SCO Heavy Duty Grounding Wire Kit [Part#: LIN-BLU]
Old Feb 20, 2007
that kit is 4ga, so you're good. did you do just the battery cable or all 3?
Old Feb 20, 2007
hwt101's Avatar
350 is CHEAP for a HO alt, the stinger brand runs about 700. And its not a truck alt it fits in the stock spot just fine didnt need a new belt or anything
Old Feb 20, 2007
MBison's Avatar
Big 3 meaning replacing the 3 stock grounding wires? Here you can see some pix of my engine compartment.
ID:	69770   Click image for larger version
Old Feb 20, 2007
I'd leave the 5AWG on the profile amp and use the 4AWG into a cap just for the sub amp. A mid/high amp won't pull near the amount of power that sub amp will.
Old Feb 20, 2007
MBison's Avatar
so i'd have to run the 4awg wire from the battery to the cap, right?
Old Feb 20, 2007
Exactly, and then 4AWG from the cap to the amp. Also, I would avoid digital readout caps and just go for a standard one.
Old Feb 20, 2007
MBison's Avatar
Hmm.. why is that?
