Re: Rear wheel seized up
Remove the rear drum. Sounds like your rear brake may have seized up. The brake cylinder may be causing the issue. Also inspect the drum, sometimes it will rust and pieces will call off and get caught in the brake assembly somewhere.
Not hard to do, there are videos online to demonstrate the process. Hardest part will be removing the drum, they can be stubborn sometimes.
