Notices
Wheels and Tires Post your wheel and tire related questions here.
Just did this tire change trick
Old Nov 19, 2013
Fuego's Avatar
Fuego is an unknown quantity at this point
So, yesterday morning, I ran over a nail on the way to work. After pulling onto a side road, that was well lit, I managed to jack my 04 civic up and take all the lug nuts off. Everything as expected up until this point.
I then try and pull my flat tire off. It doesn't budge. Almost like the lug nuts were still on. I kicked it many times but to no avail. Finally, I pulled out my smarthphone and read a tip that worked and wanted to share.
I put the lug nuts back on and hand tightened them about halfway, leaving space between the bottom of the nut and the rim. I then lowered the car back down and when enough weight was put back on the wheel, I heard a pop and that was the wheel hitting the lug nuts and becoming unstuck. After that, it was smooth sailing.
I didn't figure this out, it was something I read and wanted to share it in case someone else might need this tip. I know this might be common sense or knowledge to most of you, but it made my day yesterday morning.
Any other tire change tricks? Other useful tricks?
Old Nov 19, 2013
Tragedy's Avatar
skate or die
Re: Just did this tire change trick
Occasionally I would come across some tires like this. Usually they have never been removed, or are rusted in place. Either way, it is a good indicator of poor maintenance.
If beating it with the palm of your hand does not work, use pb blaster, and just wait. Or use a hammer on the backside of the tire.
Old Nov 19, 2013
CraigW's Avatar
I do my own rotations and use a wire brush around the center hub and wipe mating surfaces with a WD40 soaked rag.
Even then in crappy weather you get one hard to release, but never that bad though.
Old Nov 19, 2013
Fuego's Avatar
I get my tires rotated every time I get an oil change, roughly 5k miles. Is there something else I need to get teh shop to do? Is there something I can do after they rotate them?
I agree that some of the other techniques you said will work, but I wanted to let people know in case they get a flat and don't have those tools with them.
Maybe I need to get a "Just In Case" set of tools for the car.
Old Nov 19, 2013
I can tell you don't have the pleasure of dealing with anything from the rust belt.
This "problem" is dead common up here.
A few good kicks, or maybe a 4 lb sledge.
Wire brush, rust buster, anti-seize.
Old Nov 25, 2013
Poopies's Avatar
Super Moderator
+1 to what he said. My friend's GF posted a Facebook picture of three of us standing around kicking the crap out of his Accord's tire. It was embarrassing, but a good donkey-kick is all you need in the end :-)
Old Nov 25, 2013
Kennykid2002's Avatar
Kenny the Ricer
I've never had to deal with rust.
No snow, no salt in California
But I still do apply a thin layer of anti seize on the rotor hub, and the stud threads.
If you live in rust prone area, anti seize is your best friend.
I apply it on every bolt and nut I remove regardless of rust or not.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
technosilver
Nov 14, 2001 10:58 AM
