Notices
Wheels and Tires Post your wheel and tire related questions here.
Humming tires/bumpy tread
Old Aug 8, 2012
bymitten's Avatar
bymitten is an unknown quantity at this point
Question Humming tires/bumpy tread
Hello everyone,
I have a 2001, 2 door Honda Civic. I've been having this humming tire issue for some time now. After doing some searches on these forums, I thought I had an issue with a worn out wheel bearing being the culprit.
Anyways, I recently had an oil change and had my tires rotated. Driving home from there, I noticed the tires were a lot louder (just at 50km/h), the foot pedals and steering wheel vibrated much more and the humming noise could be heard also when coming to a stop. It got slightly better as I continued to drive though. I took it back a few days later and they took it out for a test drive. They showed me the tires on the front - the tread looked bumpy and uneven. They looked at my struts, I think it was, and said they looked weak and was probably the cause for the uneven wear in the back tires, which are now currently in the front.
I should also point out (and I know I'm going to get sh*t thrown at me for saying this) that I believe I've only rotated my tires once in the passed 55,000km.
My questions are:
Is it possible the bumpy tires on the front will wear back to a normal condition or will there remain like this and my back tires will eventually do the same with my weak rear suspension?
Am I better to rotate my tires now every 5,000 or 10,000km? Would this help?
Should I have my struts or whatever it is, fixed and have new tires put on? Or is it not worth that being an 11 year old car and should just run it to the ground?
Thanks for your help in advance!
Side question: I try to keep my tires at roughly 32psi and I check my tire pressure at least once every 2 weeks and noticed one of the bumpy tread tires loses tire pressure. It might be at 22psi and yet it looks properly inflated. Why is this?
Old Aug 8, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Re: Humming tires/bumpy tread
Is it by any chance the Bridgestone Potenza/Ecopia/Integrity tires.
They make very loud noises and is to be expected.
Old Aug 8, 2012
bymitten's Avatar
No, they are Michelin tires. I've had them on the car for about 3 years now and I don't recall them making this type of noise before. Then again, my car was 3 years newer. :P
Old Aug 26, 2012
bymitten's Avatar
Wow! No one has any ideas??
Old Aug 26, 2012
our old accord has michelins almost worn bald and they hum like crazy. if the sound changes when you rotate the tires, then the tires are the only thing to blame.
Old Aug 27, 2012
CraigW's Avatar
Once the tires are scalloped they will likely remain noisy.
I rotate at 5k miles.
Old Aug 30, 2012
BassMasta808's Avatar
BassMasta808 is on a distinguished road
This screams wheel bearings. I just had to do mine so I know what it sounds like, I thought it was tire noise at first also. And just from opinion stand point, I keep my tire pressure at 35 all around. I find the ride is noticably smoother.
Old Sep 5, 2012
bymitten's Avatar
That was my first thought also as I've had a wheel bearing replaced some time ago. Is it even possible for a weak rear suspense to cause the tires to become scalloped/bumpy?
Old Sep 5, 2012
foedoemoehoe's Avatar
foedoemoehoe is an unknown quantity at this point
Just ran out in the pooring rain to find potenza tires on my new car that is making a humming noise . any reason why these tires specificly ?
Old Sep 5, 2012
Some tread pattern designs are much more prone to chopping than others.
Old Sep 7, 2012
palsana's Avatar
that would be Bridgestone/Firestone Potenza G019 whose tread pattern design is so worse the costco dealer i bought it from warned me ahead of buying but did not listen and those make so loud noises on my civic its pathetic.also, in just 4 months of use, those tires are already looking real awkward.
Atleast Costco gives hazard warranty so if I get so lucky that its covered under warranty i would never really have put that back again.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
JetsterDajet
52
May 8, 2016 12:11 AM
beanhead
Sep 24, 2015 12:04 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
