Notices
Wheels and Tires Post your wheel and tire related questions here.
Steering Wheel Shake
Old Mar 19, 2010
dailycivic's Avatar
dailycivic is an unknown quantity at this point
Question Steering Wheel Shake
Good morning all,
I have a 2005 Civic LX (daily driver) that I just had new wheels/tires put on at 73K miles. The new wheels are the 15-Spoke (08W15-S5D-101B) direct from Honda. I now have a slight shake in the steering wheel at 58-60 mph and 68-70 mph.
Everything has been rebalanced and the suspension has been inspected - I have an alignment scheduled for tonight as we cannot figure out what else it could be.
Could the new wheels have a different offset than the standard steel wheels? Could this be throwing off the alignment on the car? Overall diameter really hasn't changed besides tire wear, width is the same...
Some feedback would be great. What do you think?
Old Mar 21, 2010
dailycivic's Avatar
Re: Steering Wheel Shake
Well, the steering wheel shake is gone. Toe was off, as was the front right camber. Rear toe was also just out of spec. Of course the car rides like crap in general now. Why? They put it on the alignment machine as a 06-09 civic. It's a 2005. Have another appointment tomorrow morning...I don't know how the old style civic compares to the new style on the alignment parameters but I'm guessing they are different.
Old Mar 21, 2010
BlueEM2's Avatar
Whachya lookin at?
Usually when the shake comes and goes at different speeds its the wheel balance... Mine just started doing it too when I rotated my tires It could be the alignment though. I would imagine that the spec is way different from the years of cars but I'm not sure either. Make sure they put it on as the right year and tell them to do it for free since they screwed up last time.
Old Mar 21, 2010
dailycivic's Avatar
At first, I went with balancing too because that's the typical fix for the diagnosis but this was definitely the alignment. Some measurements were off the chart to start and the car seemed to be skewed to the left. The shake is completely gone but the car doesn't ride right. There is no "return to center" after making a turn and the car seems a little twitchy over 70mph. I think we'll start with camber tomorrow morning and go from there...
Old Mar 21, 2010
BlueEM2's Avatar
Whachya lookin at?
Best of luck hopefully that fixes it Don't forget to post if it fixed it!
Old Mar 21, 2010
FALKEN's Avatar
Civicforums Junkie
first... take it back and have them align the car to the correct specs.
second... did your new wheels come with hub-centric rings?
Old Mar 22, 2010
dailycivic's Avatar
All is good after this morning's appointment.
First thing we did was a test drive. I actually went out with the mechanic (him driving) and he noticed exactly what I did.
The mistake putting it under the 06-09/10 model actually made sense because the build date on the door jamb, actually falls under a 2006 model designation but it was just a very late 2005 build. As I remember, it was the last one the dealership had when I got it in September of that year...it was new with just 9 miles.
Anyways, we typed in the VIN and used it instead of the door jamb sticker and the machine ran with 03-05 specs. The alignment specs are totally different for the earlier model and the car now rides like new.
BTW - These wheels don't use the hub centric rings. They have tapered lugnuts to center the wheels on the hub.
Old Mar 22, 2010
BlueEM2's Avatar
Whachya lookin at?
Sweet!
Old Mar 23, 2010
FALKEN's Avatar
Civicforums Junkie
FYI - lugnuts are not going to center the wheel on the hub, but anyways... glad you got the issue fixed.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
