Notices
Wheels and Tires Post your wheel and tire related questions here.
2000 civic EX changing wheel size
Old Jan 17, 2010
wadefish's Avatar
wadefish is an unknown quantity at this point
I have a 2000 EX that currently has 14" wheels.
First, a basic question... can I mount 15" wheels/ tires on the car (assuming the 15's have a matching lug pattern)?
Also, I'm wondering what considerations come in to play regarding speedometer and odometer.
If the new wheel / tire combo has a different circumference, is there a way to adjust the instrument panel accordingly, so that speed / distance remain accurate?
thanks for any help.
Old Feb 2, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: 2000 civic EX changing wheel size
You can move up to 18 inch if you really wanted, but I would not.
Basically the term is called plus sizing, for 15 I believe it is 195 50 15, make sure you get the proper offset and lug sizing for your car. Most vendors will have the recommendations for each car. When you plus size it will not affect the speedo and odometer for the most part, I have 16's on mine and the speedo is off like 2mph, actually it reads 2 mph less than it should be.
Old Feb 6, 2010
wadefish's Avatar
Thanks, civicpapi. Very helpful.
Old Feb 8, 2010
04 Honda Civic's Avatar
What about abs sensors does wheel size effect them, I thought it did?
Old Feb 8, 2010
civicpapi's Avatar
If you do what I typed above ABS sensors should be just fine, since plus sizing keeps the overall diameter of the original wheel. People run into issues when they go way too big for the car, looks good for show, but for real world driving it is not practical.
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
