Notices
Wheels and Tires Post your wheel and tire related questions here.
question about brake rotors
Old Oct 22, 2009
sodaCAN's Avatar
sodaCAN is an unknown quantity at this point
Question question about brake rotors
hey guys, replacing all my brake pads and rotors because my car shakes horribly when braking. now, instead of replacing the rotors, would just getting my rotors and drums turned be sufficient? just want the shaking to go away
Old Oct 22, 2009
CraigW's Avatar
Re: question about brake rotors
You should replace the rotors, turning will only be a short term fix.
Get OEM or a good quality replacement.
Old Oct 22, 2009
just replace everything pads and rotors and then try to go easy on the brakes (no riding them, no using brakes above 40mph unless you have to, etc).
Old Oct 22, 2009
sodaCAN's Avatar
yeah im usually really good about my brakes, now, is it bad to let it hang in gear and slow it down that way? i usually only do that at 45~ mph speeds. ive done it because my brakes are messed haha. i saved this car from an ill fate. almost EVERYTHING is factory. i got the car at 144k miles and everything was factory besides the oil filter and the front brake pads. the fuel filter, air filter, cabin filter, nothin was changed.
but sounds good, thanks guys. picking up rotors and pads tomorrow.
Old Oct 22, 2009
sodaCAN's Avatar
ugh, another question lol. i would think that i can just turn my brake drums for now, or should i replace those as well. they look fine. i do know for a fact my front rotors are pretty warped tho.
Old Oct 22, 2009
yeah the drums are maybe only 18% of your braking power. so they are rarely damaged by excessive heat (unless you forget the parking brake on for miles lol). the fronts i would just replace the rotors with oem. and no theres no problem letting the car slow down by itself in gear.
Old Oct 22, 2009
lordhelmet's Avatar
Make sure your lug nuts are torqued evenly. I've started doing this and noticed (with the exception of high speed braking repeatedly) that I rarely have vibration from the brakes.
Old Oct 28, 2009
sodaCAN's Avatar
hmm... yes i tried to remember the 5-star pattern... i might have done it wrong. Buying all new tires next weekend, so i will just make sure they do it at the shop.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
DAC
Jun 18, 2015 10:00 PM
bsmiley
Apr 27, 2015 01:27 PM
tattedlariat
Apr 17, 2015 03:26 AM
nymbus2k
Dec 17, 2001 04:57 AM
