Notices
Wheels and Tires Post your wheel and tire related questions here.
Wheel Bearing?
Old Oct 14, 2009
Lionsmane38's Avatar
Lionsmane38 is an unknown quantity at this point
Wheel Bearing?
Hey guys. I drive an EM1. I think that I have a problem with my wheel bearings. When I am driving I get a loud almost rubbing sound from what I think is the wheel bearing. I can feel the vibration in the pedals. It's almost like something isn't lubricated correctly.
When I get up to about 60 mph the noice decreases and when I turn right the noise stops almost completely.
Could this be bad wheel bearings? I looked on JC Whitney and they only have the bearings for the cars with rear drums. As you know, that wouldn't do any good for me because the EM1's have discs on all four. Let me know guys. Thanks.
Old Oct 14, 2009
Re: Wheel Bearing?
Bump
I talked to a guy at work today and he asked me if any of my inner fenders are hanging down and sure enough the front driver's side is, but I don't think it's hanging low enough for the wheel to rub. I don't know. I'll have to screw it back up all the way and see it the problem is better. I have a gut feeling that its more than that.
What do you guys think?
Old Oct 16, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Wheel Bearing?
If the EM1s have heat shields for the disc brakes on the front it could be that. I had a rubbing noise on the front end of my EM2. It would do it going straight, but it would get worse turning left. Turning right it would completly dissapear. It turns out that the heat shield was rubbing the rotor. I took the wheel off to inspect and bent the heat shield back away from the rotor and the noise went away. It might not be it, but its worth taking a look at.
Old Oct 16, 2009
Re: Wheel Bearing?
Awesome. thanks man. I will check that out too. I haven't had the chance to inspect anything, because it's colder than hell here, but I will keep you guys posted.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
muniorbust
33
Aug 31, 2015 08:59 PM
denierlexiese
Aug 5, 2015 08:58 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
