OEM Civic Lug Nut Split Washer.......
I have a 01 EX and a 02 LX with stock wheels and covers. Each of these vehicles have (2) lug nuts on each wheel missing the small black washer that holds the wheel cover on. I surely don't want to purchase new lug nuts just to get that small little spit washer! That would be quite an expense, but still cheaper then buying a new wheel cover when it goes flying off though.
My question for the masses here, is there an aftermarket source to purchase just these split washers so you don't have to purchase new lug nuts?
If I cant find a source, I was sizing up 3/4" schedule 40 PVC pipe that has the inside and outside dimensions I need, all I will need to do is slice 1/8" thick "washers" and then split them from OD to ID to make them work, but if I can buy just the washers I'd rather do that.
Let me know......
Thanks,
Craig
