Notices
Wheels and Tires Post your wheel and tire related questions here.
Knocking Sound on '02 Civic?
Old 08-13-2009
20_CiViC_02's Avatar
20_CiViC_02 is an unknown quantity at this point
I've noticed lately that when I apply the brakes lightly and a low speed, I hear what I interpret as a knocking sound coming from the front driver's side wheel. If I am travelling at around 50 km/h and slow down to come to a stop, I usually don't here it, but as the car slows down to 5 or 10 km/h, I can hear it. I even tried driving at about 5 km/h an hour with my foot lightly on the brake and could still hear it.
I have a 2002 Honda Civic LX. Any ideas about what this noise could be? We talked to a mechanic and he said it could just be a "safety clip" on the brake that has come loose.
Old 08-13-2009
badhabits's Avatar
badhabits is an unknown quantity at this point
Re: Knocking Sound on '02 Civic?
Does the sound only happen when breaking?? mine makes a ticking sound when driving at low speeds 5-20mph, which wound up just me having loud injectors
Old 08-13-2009
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Wheel nuts loose / missing / nicked
broken spring
loose /worn front wheel bearing
CV / ball joint
My guess would be cv joint or wheel bearing. If it's your wheel bearing, it'll get louder very soon and I'd advise against driving on it. Jack up your car and try to shake your wheel from side to side. If you're able to then take it to a garage.
Old 08-14-2009
04 Honda Civic's Avatar
Yea, I would advise you do what Dex said shake your wheel in all directions and see if its loose. If not then you can rule out ball joints and bearings.
Old 08-19-2009
I just got my timing belt done a few days ago, and the mechanic checked the breaks, trans axle and CV joint and nothing is wrong. I did jack up the car and wiggled the wheel in all directions and there was no movement.
bsmiley
04-27-2015 01:27 PM
Linda0818
04-23-2015 11:30 AM
artychris
09-03-2001 03:39 PM
Strychnine
08-15-2001 07:07 PM
Strychnine
08-15-2001 07:07 PM
Quick Reply: Knocking Sound on '02 Civic?
