Notices
Wheels and Tires Post your wheel and tire related questions here.
Dezod Front pads fitting issue!need help.
Old Apr 18, 2009
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Hello I have a 2004ex. A whyll back i bought some dezod front pads.I was going to use them on the circuit but i ran in some
problem getting them in the caliper!
1.width of the dezod pads is 1mm larger, i would have to file them off.
2.Pad surface is almost 1cm smaller than my stock pads.
3.Sinds the pads are smaller the clips on the pad comes higher, this clip will hit the clips in the caliper, making it impossible
to push in.
4.mailed paul @ dezod said had no problem before!
Does anyone has an idea?thx
Dezod left - Stock right
Old Apr 18, 2009
TRIZ's Avatar
Re: Dezod Front pads fitting issue!need help.
Wow hmmm... from the pics it looks like they are totally different. I dunno, cant really see anything that sticks out from those pics. Can you get some wider shots of the pad sitting in the caliper?
Old Apr 19, 2009
DaRk_MauL's Avatar
Hey triz,
here are some better pics i hope!
the caliper.
Stock outside pads between the clips like they should.
Stock inside pads between clips and the clip on the pad is underneed the caliper clips.
Dezod outside pads are just 1mm wider not going between the caliper clips.
Dezod inside pads not going in because the height of the pad is smaller!
this makes the clip on the pad hit the caliper clip.
Old Apr 20, 2009
DaRk_MauL's Avatar
Morning Bump
Old Apr 20, 2009
TRIZ's Avatar
I dunno man.... I think dezod needs to see these pics and maybe he can see something I'm missing. I've only messed with the brakes a few times and had no problems, but never bought dezod pads.
Old Apr 21, 2009
dezod's Avatar
7thgen Power Maker
Him and I have already discussed this and the conclusion is that apparently his UKDM Civic has different braking components than the USDM Civics. He has rear discs as a default, which we do not. I feel he may use our RSX or Civic Si system.
He purchased these back in 2007 too....
Note he is in Belguim
Old Apr 24, 2009
DaRk_MauL's Avatar
bump does no ones have any idea?
Old Apr 24, 2009
looks like they wont fit. there are quite a few differences just between 01-05 civic models, im having to resort to acura parts for some items that do not fit and i have usdm civic. im sure the euro civics have even more parts that are different. but dont force something that wont fit the way its supposed to esp with brake pads.
Old Apr 24, 2009
DaRk_MauL's Avatar
I guess i will have to sell them because there is no way they will fit.
How can i find out what us type that is the same as my calipers? So i can find the right
pads next time.
edgenet
Apr 28, 2015 07:49 PM
bsmiley
Apr 27, 2015 01:27 PM
jonavin
73
Oct 4, 2004 07:18 PM
BeefMan
Nov 25, 2001 10:38 PM
ademarco6
Nov 16, 2001 10:19 PM
