Notices
Wheels and Tires Post your wheel and tire related questions here.
WHY won't my wheels come off!?
Old Feb 10, 2009
bumpincivic00's Avatar
bumpincivic00 is an unknown quantity at this point
okay soo i'm having a bad day and last night my friend gave me some rims so i was like forreal?. SO today i figured i'd put them on only to find out my wheel won't come off...what am i doing wrong?... i have a 2000 civic ex, i jacked up the wheel took off the four lugs and then nothing...is there more to the process?...ooh and so i put it back together and moved my car to find out now it squeaks?!?! can anyone help me out and make my day better? thanks guys...
Old Feb 10, 2009
ballistic's Avatar
ballistic is an unknown quantity at this point
Re: WHY won't my wheels come off!?
Try hard, bang them off, they're probably rusted on or something.
Old Feb 10, 2009
yea i did, i punched and kicked and pushed and pulled...and then to top it off now it squeells..(<--sound it out bc i don't think i can spell)...and yea so tomorrow i am going to attempt again but with wd40 maybe it will break it off...
Old Feb 10, 2009
DDragon7's Avatar
Loosen the lugs, and drive around the block, after that, it will be loose.
Old Feb 10, 2009
haha yea and with my luck i'll loose a wheel some magical way lol...but if all else fails i will most likely try it lol so thanks for the good idea i'll try it tomorw
Old Feb 10, 2009
TRIZ's Avatar
Thats odd. Hmm... in for what happens with this.
Old Feb 11, 2009
mad_ox1's Avatar
mad_ox1 will become famous soon enough
I had to bang the wheels of my GF's Camry a while back with a sledgehammer. Just lie under the car and whack towards the outside. Rust is almost certainly the issue.
Old Feb 11, 2009
CraigW's Avatar
For the noise you may have bent the thin metal plate against the brake rotor and it could be scraping ??
I always wire brush the area and wipe down mating surfaces with WD-40 each tire rotation to keep them from sticking.
Old Feb 11, 2009
TRIZ's Avatar
^ I Never thought about that... hmm. I'm out in oregon, no salt on the roads... so we really dont have any rust on our cars no matter how old they are.
Old Feb 11, 2009
MidnightRook's Avatar
MidnightRook will become famous soon enoughMidnightRook will become famous soon enough
There's a tool for getting them off.
It has..three prong things. Two things clip on either side of the rotor, the middle goes on the middle part where there's space. Then like turnicette (spell check) you turn and then pops off rotor.
Have you tried crowbar?
Old Feb 11, 2009
ok sooo today i got at it once again and i got it using the hammer and wd40 worked nice and i wiped the pad and played with the pad a little so the sound is gone i hope its not temporarily but we shall see..and then the best part is..the rims didnt work lmao. they were "universal" allwell..thanks guess helped alot and i also cleaned the inside part of the rim that sits on the rotor with wd40 so it wont stick hopefully thanks again
Old Feb 12, 2009
DDragon7's Avatar
Use anti-seize when you put them back on.
Old Feb 16, 2009
04 Honda Civic's Avatar
X2 yea if u grease up the whole lug the wheel shouldnt stick and the bolts would be easier too
Old Feb 16, 2009
DDragon7's Avatar
You shouldnt put grease on the threads for the lugs. That would change your required torque specs.
Old Feb 25, 2009
betancivic2k4's Avatar
betancivic2k4 is an unknown quantity at this point
take off all the lugs then from the back side of the wheel bang it with a big rubber hammer and it will sure come off. but kee on rotating the tire while u do it.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
cmart1209
May 29, 2015 04:52 AM
bsmiley
Apr 27, 2015 01:27 PM
insan
Detailing
Jan 29, 2002 09:41 AM
ImmortalEX
Jan 2, 2002 08:45 AM
