Notices
Wheels and Tires Post your wheel and tire related questions here.
lug nut specs????
Old Jan 9, 2009
D16Fiend's Avatar
D16Fiend is an unknown quantity at this point
lug nut specs????
what size lug nuts go on my car. 2000 civic ex
12x 1.5?
Old Jan 9, 2009
04 Honda Civic's Avatar
Re: lug nut specs????
are they the same as 7th gens? I can measure mine, you dont have any old ones to compare them to?
Old Jan 9, 2009
D16Fiend's Avatar
yes i do but i need to know the thread and everything to order new ones online. i guess i will just have to go to the parts store and thread it onto a bolt to find out.
Old Jan 9, 2009
yeah its same for all civics excluding 2006+ models, M12xP1.5 and you torque them 80 ft/lbs.
Old Jan 9, 2009
D16Fiend's Avatar
thanks. appreciate the info
Old Jan 23, 2009
OOO-ROB's Avatar
OOO-ROB is an unknown quantity at this point
This Guy is Correct!!
Old Apr 17, 2009
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
which lug nuts can i use on aftermarket wheels, for example rota gt3. Because i read somewhere oem lugs will fit but not properly with aftermarket wheels
Old Apr 17, 2009
any aftermarket lug nuts will work, just dont try to fit oem or it will ruin the hub. just get the right size of aftermarket, M12x1.5
also, aftermarket lug nuts cannot be used on oem wheels. its a different taper seat.
there are all kinds of brands, muteki is cheap and lightweight, i like em. there are other expensive ones like rays, skunk2, etc. check passwordjdm.com for a bunch.
Old Mar 14, 2010
ross3093's Avatar
ross3093 is an unknown quantity at this point
So I lost 2 lug nuts last night, I picked up two from wall-mart some guy fished them out of the bin, should I use them or not?
I have Oem everything.
Old Mar 20, 2010
make sure they look the same as oem as far as the seating shape on the back.
Old Mar 21, 2010
civic0918's Avatar
civic0918 is an unknown quantity at this point
just get tuner lugs at a shop thats what we call them in pa anyway. The shop will tell you what size you need.Then you just pick your color and thats it good luck hope all works out for ya.
Tedverseti
Apr 23, 2020 01:45 PM
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
stank
Sep 16, 2015 07:40 AM
siliconvalley
Sep 15, 2015 09:48 PM
