Notices
Wheels and Tires Post your wheel and tire related questions here.
Knocking noise coming from rear wheel
Old Aug 8, 2008
mrb420's Avatar
mrb420 is an unknown quantity at this point
So I recently had my tires rotated. To my dismay, the guy changing them jacked my car until the it looked like it was going to fall on it's side. About a week or two after the rotation, I noticed a knocking noise coming from the rear. I thought maybe it was something in my trunk. But recently, the noise is my pronounced and seems to be coming fromt he left rear wheel. The noise stops when breaking and sounds louder when driving slow.
Is it possible that this is due to the drum brakes? Need replacement? Loose cover?
What about the shocks/struts?
I'm gonna take off the tire this weekend and look around the area.
What should I look for?????
Old Aug 8, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: Knocking noise coming from rear wheel
stock the car and check your lugs first. if they're tight, poke your head underneath and look for anything that may be rubbing/bumping something esp looking for a bent wheel.
if that's all good, take the tire off and check all susp mounting bolts/nuts.
good luck
Old Aug 10, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
OH SNAP! Yeah that sounds like loose lug nuts to me. This one time I frickin drove with loose lugs nuts, made the same kinda noise, I thought I was gonna die! Tighten them down, see if it goes away.
Did you do any brake service recently?
Old Aug 12, 2008
manahoonie's Avatar
dealership did that to my dad one time...each one was only on 2 or 3 turns with the hand....he gave them a nice ear-ful (Army Lt. Col. RET. )
Old Aug 12, 2008
i got back from sears once and my lug nuts were barely 20 ft/lbs. you tell em not to use the impact and they take you seriously! lol. he mustve used a socket wrench. no big deal for me tho at all, i always double check my ish and retorque them myself.
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Sparty
Nov 15, 2001 04:55 PM
crazydragon
Nov 7, 2001 05:13 PM
SleepyT
Nov 1, 2001 04:59 AM
