Getting my car ready for this years track season, I will be doing alot of track days this year and among the other things I am looking to change one is brake cooling. I am not sure just how well my brakes will hold up, but I am guessing some cooling is going to be much needed. So I have decided to make some brake ducts, the idea is this:
I am going to run some 2" diameter rubber duct material to the brakes with the opening attached inside of the fog light opening. I think that the key with this is to get the cooling directly to the brake rotor. To acheive this I am goning to cut a 2" diameter hole in the brake shield and weld a flange on the backside. I will then be able to attach the duct material to the flange via a hose clamp, supplying air directly to the rotor. I have seen this design done before, but not with 7thgens. If I go for it I will use this thread to outline the DIY.
This is just one of the seemingly billon tasks I need to do to get my car ready
, but I will be sure to post it up once it is completed.
