Notices
Wheels and Tires Post your wheel and tire related questions here.
brake change= severe smoking/smell HOT
Old Jan 12, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Yeah So my brake pads were TOAST.... So I went and got new ones. I installed them and everything was okay.
Things that arnt right:
The little screw the holes the caliper how it goes in and out (hard to explain one of them is frozen and wont move (the bottom one) and the top one works fine... Also when i push in the brake I feel force but if i remembered correctly the last time I did it it was like I could barely touch it and it will stop.
Should I flush out the brake line? or because of that pisting thing that holds the caliper on is that why its smoking? I just don't want to start a fire from this....
But before I switch the brakes everything worked fine.
Old Jan 12, 2008
Maple50175's Avatar
Re: brake change= severe smoking/smell HOT
well my brakes like caught on fire... I was going to my friends house to check it out and the rotor was RED HOT like glowing orange.. im ****ed now...
IDK whats wrong. Could it be the caliper? I think of of the 2 pistons were stuck.. or HARD to push in..... I need to fix this tommrow ahhh
Old Jan 12, 2008
TRIZ's Avatar
Well my first thought was you got something on the pad/rotor like antiseize or break quiet. But if they are red hot, then thats def not the case. did you push the pistons all the way back inside the calipers?
Old Jan 12, 2008
Maple50175's Avatar
yes I pushed it back in with a C clamp..
i think it sthe caliper..
Im gonna buy an autozone one tommrow..
Old Jan 12, 2008
my bet is you dont know how to install brakes. dont mess with something so important if you cant do it right. if they were fine before you worked on it, then its something you did wrong.
Old Jan 12, 2008
greeen01civic4d's Avatar
my bet is u didnt lube the slides... its the most common problem with brakeinstalls, it causes the caliper to stick, causing too much friction on teh rotor, making it heat up and glow
Xuhme
21
Aug 7, 2023 03:40 PM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
jc33312
May 12, 2015 03:17 PM
lildoo
May 9, 2015 09:44 AM
02Si
Dec 14, 2001 10:26 AM
