General interchangeable parts for 7th Gen cars
Old Apr 7, 2017
Re: 2005 hood, bumper cover, headlights interchange
I'd urge you to research part numbers for various versions of the cars in an online Honda parts catalog
Here's just a few dealers with online catalogs, I'm sure there are many more and most sell online at wholesale prices
hondapartsnow
hondapartscheap
bkhondaparts
hondaautomotiveparts
.com/
Old Dec 20, 2020
To make it nice and readable, here are the things you can interchange:
  • 01-03 coupe/sedan: bumpers, hoods, fenders, lights, spoilers, and other body parts including doors, handles, etc.
  • 01-05: engine/transmission stuff, just about any interior item, most suspension parts, wheels, brakes
  • 01-02: front struts (crash bolt was changed from 14mm to 16mm in 2003)
  • 04-05: you can install rear tail lights from an 04-05, but it requires a socket change or some MacGyvering for... I think the rear brake light. Or was it the turn signal. One of the two.
  • RSX: shifter assembly (if manual transmission), engine if you feel like doing some work, rear sway bar, e-brake cable assembly (if doing a civic Si rear disc conversion), Front seats (one hole needs to be drilled out a bit). There's probably a lot more, but those were the common ones.
  • Civic Si hatch: rear disc brakes (takes some doing, but pretty much bolt right in, but you'll need a different e-brake cable. 2002 retained the 4x100 lug pattern. 03-05 they changed to 5x114.3), front seats (one hole needs to be drilled out a bit), engine if you feel like doing some work (same engine as RSX, in fact). There's probably a lot more like the RSX, but those are the common ones.
Universal stuff:
  • Wheels: as long as they have a 4x100 lug pattern and have an offset of +35 to +45, they should fit. 14-18 are common sizes people put on the 7thgen. 19s and 20s if someone was feeling frisky.
  • Lug nuts: as long as they're M12x1.5 thread pattern. If you have OEM wheels, they need to have a ball seat. Most aftermarket is 60-degree conical. Honda Mugen rims have a 45-degree conical shape.
  • Shift ***** (if you have a manual transmission): if it has an M10x1.5 thread pattern, you're good.
M00n3at3r
Jul 2, 2013 05:12 PM
pmjr0987
Jun 7, 2012 08:04 AM
dragoon
Nov 14, 2002 08:40 PM
Pir8pete
May 1, 2002 12:00 AM
prototype
Feb 28, 2002 05:58 PM
