transmision
Old Aug 29, 2018
Brendon1936's Avatar
Brendon1936 is an unknown quantity at this point
transmision
I have a manual 05 ex special edition coupe and I am trying to find a longer gearing for the transmission since 60 is about 3000 rpms I want to find something that is a little bit lower I have done some reading and people say the 6th gen trans work with the 7th
Old Aug 29, 2018
Slumpertcivic's Avatar
Re: transmision
Bigger tires usually does the trick.
Old Aug 29, 2018
Colin42's Avatar
Re: transmision
6th gen has a totally different shifter set up (linkage instead of cables) don't think it will work
so you have a d17a2? (vtec motor)
you can use a non-vetc trans (d17a1) for longer gears.
it bolts right in no modifications needed.
I did the opposite with my old car, I put a vtec trans in a non-vtec car because I wanted shorter gears for passing people quicker.
Old Aug 29, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: transmision
just leave it alone. it's geared like that for a reason. 3000 rpm is not high or taxing for a honda. we cruise for hours and hours in 6th at 80 mph /4000 rpm. if you could find a trans with lower/diesel gearing, you'll find yourself with a car that need the gas pedal pressed farther due to the increased load and in the case of an automatic, you'll find it needing to downshift more often when you approach a small hill or try to speed up a couple mph. i really really doubt you'd pick up any mpg that would make your swap worthwhile and you will likely see your non highway mpg drop. hondas are geared efficiently as is, smart engineers were thinking when they created your transmission
TimMH
Transmission
Oct 12, 2019 07:06 AM
Duckracer
Nov 19, 2017 08:29 PM
Civility
Nov 17, 2015 10:04 AM
frosty92jdm
Jan 4, 2014 10:05 PM
Dmans99
Mar 30, 2013 09:39 AM
