View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#271
Re: How strong are our engines built?
I'll let Ezone or other longtime Honda mechanics answer that one. I've owned two D16Y8's and my mom has a D17. I like them both and would say based on my experience they are both solid engines and easy to work on. Never owned a K-series so I cannot opine on them. Oh, almost forgot..I do own a Honda pressure washer and it's never failed to start or run over the past ten years.
#272
Re: What is the “ideal” oil level?
Wrong all the way around IMO.
The oil level is inconsequential for warmup time as long as it has enough. (If it doesn't have enough, it won't warm up ever again)
Engines HAVE to be able to run cold. You're in a place you barely even see real cold.....and the people in the freekin arctic circle don't have the kind of problems you are thinking about.
No, you probably shouldn't hotrod a stone cold engine (at least give it a few seconds to get the oil flowing FFS) but doing so probably isn't going to do a lot of harm in the short term.
Oil technology these days is light years ahead of what your dad and grandpa and great grandpa grew up with.
Engineers already took this into account. Anywhere between the low mark and high mark is safe.
My personal preference is the full mark.
#273
Received 1,149 Likes
Rep Power: 485 Re: What is the “ideal” oil level?
Stick with the 3.7qts as laid out in the user manual and call it a day.
#275
#276
wait, you're supposed to check oil level? /s
All kidding aside, you're terrifyingly right with that remark x_x
#277
I don't check the oil in my Civic or the GFs Fit. Yet.
OK I checked oil in my car on Saturday just before I changed it.
I checked the Fit around halloween (MM=50%)and I figured it was fine to go until the wrench light comes on.
My car just turned 30k (6 years), and the Fit just rolled 30k on my rebuild (2 years).
I check oil in the truck and the bike a lot though.
#279
solid rike a rock..
i clocked 315k miles and purrs like a kitten.. my tranny just lost reverse is slower, but forward gears are going fine.. I dont know why, because i thought reverse is the one at least not used that much..
I can attest to some durability parts and i have the data to back it up.
original water pump still on it.., original timing belt tensioner, hasnt failed yet.. though i might change it this spring 315k miles, i been checking it once a year but has to be close to failure..
i finally have slight burn of oil due to oil rings stuck, but compression is 210 in all..
and leakage test is fine. **** i can just take them out and clean them and still get 200,000k.
headgasket let go on mine at 258,000 miles.
still have original exhaust all of it, and I live in upstate NY Rochester where is a snow salt belt state. body has few rust spots nothing major..
paint is peeling somewhere clear coat..
what else i have stats ask me i probably can give you aproximate lasting times of OEM.
you must have done something, or something happened.. what was the failure?
honda has one of the strictist quality control like toyota and ****...
#281
solid rike a rock..
#282
solid rike a rock..
#283
#284
I adjust the valves every 50K miles and it never severely overheated before it exploded. Once it got to 235 degrees when the water pump failed, but I immediately stopped before anything was damaged. And no, the head gasket didn't fail before it exploded.
#285
Received 1,449 Likes
Rep Power: 339 Re: How strong are our engines built?
what makes you believe no damage done?
#286
I meant to say "almost" severely overheated the engine since I almost didn't notice the temp. And I highly doubt that a timing belt tensioner issue that didn't cause the valves and pistons to hit would cause the pistons, rods and bearings to fail 5K miles later.
#287
Did you purchase the car new or used?
If used, was the head gasket ever breached or engine overheated?
What I'm getting at is if there was ever a scenario in which anti-freeze mixed with oil and coated the engine internals for an extended period it could cause expedited engine wear and possibly lead to the damage you mentioned.
#288
#289
Rep Power: 339 Re: What is the “ideal” oil level?
anywhere between the marks.
#290
I think that there is enough of a safety margin that the engine could be safely run with the oil level slightly overfilled or slightly under filled without causing damage. My friend ran his Civic 2.5 quarts low on oil by accident with no ill effects.
#291
Received 1,131 Likes
Rep Power: 192 Re: What is the “ideal” oil level?
That is way too low. That will cause damage, especially if done repeatedly for long periods of time
#295
Which spark plugs are best for performance?
I have heard that copper spark plugs are far superior to platinum and iridium in performance, even though they have to be changed more. Is there any truth to that? I don't mind changing copper spark plugs more often if they perform better. So do copper spark plugs actually make a better spark than platinum or iridium? Thanks.
#296
Re: Which spark plugs are best for performance?
Allow this to "Advance" your knowledge base: https://shop.advanceautoparts.com/r/...en-spark-plugs
Don't think you can find copper plugs in the recommended NGK line for your 7th gen..but, I could be wrong. Honda's are very particular with spark plug manufacturer brand as well.
#297
#298
Rep Power: 485 Re: Which spark plugs are best for performance?
You're not gonna notice enough of a difference to matter. Copper, while it'll conduct electricity better, will wear down far too quickly. Iridium being a hard metal will last longer, but they're pricey. Back when I was looking up spark plugs for turbo (was boosted in my 2002 for a hot minute), Denso Iridium IK22's were the go-to plugs for boosted D17s. Installed those in 2007, and only did one more spark plug change (to NGK iridiums) after that. I think I paid $30 for 4 of the IK22's and $25 for the NGKs.
#299
#300
General consensus in the internet world is don't use copper on distributorless ignition systems. They'll wear out far too quickly.
Honeywell is a rather large company. In the aftermarket world, they're known for Garrett turbochargers.
From the link The Great Mr. Dong provided
From another random link found while googling
“Copper core single platinum spark plugs are not designed to withstand this reverse polarity firing and will suffer premature gap growth due to center electrode erosion. Gap growth will stress ignition system components by requiring more voltage to fire,” said Dave Buckshaw, Honeywell CPG trainer for the FRAM and Autolite brands. “This degradation can be noticeable as soon as 20,000 miles after the plug is installed.”
Copper spark plugs are best for older (pre-‘80s) vehicles with low voltage distributor-based ignition systems. Don’t use copper spark plugs in high-energy distributor-less ignition systems (DIS) or coil-on-plug (COP) ignition systems. They’ll wear out too quickly.
Though many technicians and do-it-yourselfers believe that copper core plugs can be used on waste spark DIS ignition systems, Autolite says that is not true. Ordinary copper spark plugs may function well initially, but the electrodes will wear prematurely and eventually cause ignition misfire.
