Wow...my d17 hit 9k...damn miss shift):
Old Mar 17, 2012
Xiao's Avatar
Xiao is on a distinguished road
So while on my way to work down on 160 West, I was trying to pass this car in front of me, I went from 5th to fourth, then fourth to third. When I went for a third to fourth shift, it went into... second, thinking in went into fourth. Luckily it didn't damage anything severely. It went from 4k to 9k and immediatedly I took it out into neutral. D17a2 miracle. Thank you amazing technology.
Thought I should just say this to my fellow civic brothers and sisters.
Old Mar 17, 2012
Kennykid2002's Avatar
Kenny the Ricer
Re: Wow...my d17 hit 9k...damn miss shift):
Thats good nothing blew up, I'd prolly defecate myself
Old Mar 17, 2012
BlueEM2's Avatar
Whachya lookin at?
The good ol' money the shift.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1209& transactionid=1332032761-1732385193&posted_by=BlueEM2_www.civicforums.com&y outube_video_id=wtaB3oUsVJQ[/autostream]
Old Mar 17, 2012
Xiao's Avatar
You have no idea...I would defecate myself and scream...
Old Mar 17, 2012
Kenny the Ricer
No...
I'd prolly just sit there...and defecate myself... >.<
Old Mar 17, 2012
MatthaiN's Avatar
MatthaiN is an unknown quantity at this point
Didnt even know the D17 could get to 9k. haha
Old Mar 17, 2012
technically there's a time delay for any sensor to react and usually the engine runs slightly higher than the rev limiter (1k in some case) before the fuel cut goes in.
However, his case is the engine rev due to misshift, so the engine WILL rev up due to the car momentum, not fuel or throtle.
Old Mar 18, 2012
Xiao's Avatar
"VEGETA, WHAT IS HIS RPM AT?!"
"ITS OVER 9000!!!"
Old Mar 18, 2012
Xiao's Avatar
So would the fuel cut still kick in before biting the dust? or would it have continued until kaboom? I felt like an idiot when it all happened. Next thing I know when went into 2nd, there was just a sudden "wall" that stopped my momentum.
Old Mar 18, 2012
BlueEM2's Avatar
Whachya lookin at?
It will continue until it explodes. The movement of the transmission forces the engine to rev above the limiter.
Old Mar 18, 2012
when upshifting, the limiter holds the engine, but downshifting... all depends on the left foot releasing the clutch or the clutch going before the engine. either is bad.
Old Mar 21, 2012
04 Honda Civic's Avatar
I am pretty sure that you didnt hit 9k.
On S2000's we have problems cracking our valve retainers on mis shifts. I advise you pull your valve cover and inspect your retainers before one of your valves drop.
Broken retainers have no warning signs.
Old Mar 22, 2012
96DXSiR's Avatar
That's SiR to you!
96DXSiR is an unknown quantity at this point
The rev limiter on my tuned B16a ECU is set at 9800. I have SuperTech titanium valve train kit. I also have an extra set that I am wanting to sell. But anyway, I've had my B16 up to 9k before while racing but there wasn't much point because I could feel the power fall off before that point. I just wanted to see the needle hit 9 lol!
Old Mar 24, 2012
dred's Avatar
dred is an unknown quantity at this point
I did the same merging on a 4 laner in early
december, went from 3rd to second while shifting at 6000 rpm
Then about two weeks later i was sitting idling and noticed my heat way up.
Ended up bein the dreaded Head Gasket.
Not sure if my miss shift caused it but just seemed like a coincidence.
Anyway running good now with only 85000kms
new HG,water pump timing belt thermostat plugs ....1500 later
Old Oct 4, 2012
raymondxcho's Avatar
raymondxcho is an unknown quantity at this point
Don't really want to revive an old thread but a few weeks back, I taught my friend how to drive stick shift on my Civic. After two hours worth of lessons, we took a trip from LA to San Francisco. I let my friend take us up north and I drove us back. When my friend drove, there was one time when he misshifted from 5th at like 3k? to 2nd. I couldn't tell how high he revved in 2nd bc I was on the passenger seat. But damn, I felt so bad for my car. Never heard her rev that high.
Just wanted to share.
Old Oct 25, 2012
Xiao's Avatar
ahh we win some, we lose some. Honestly, so far my car has been doing well. I hope yours is well lol. Some reason though, I think that mis-shift caused my throwout bearing to become noticeably louder.
Old Oct 25, 2012
Largen's Avatar
Largen is an unknown quantity at this point
Ah I have done this on my D15 and my D17 ha ha :x so far both came out un-harmed ha ha
Old Jan 9, 2013
l36EM2's Avatar
l36EM2 is an unknown quantity at this point
a couple days ago i was doing about 55 and went to down shift from 5th to 3rd but instead hit first and now i have 2 dead cylinders in my d17a2, the timing belt is brand new and marks still line up no engine noise or nothing it just threw up misfire codes for cylinders one and 2 so i checked compression and there is zero on both cylinders but 3 and 4 have 155psi, any one know what may have happened? i am an experienced tech, i have done my share of heads and timing belts etc, but dont really feel like pulling the head off this thing during the winter if there is a known issue with it thats quicker to fix, i checked the cam also and its not broken, doesnt smoke while it runs, no knocking or ticking noises, just sounds like a lawn mower becasue only 2 cylinders are firing
Old Jan 11, 2013
Gaud's Avatar
Gaud is an unknown quantity at this point
How exactly did you manage that? Shouldn't it be locked out of first at that speed?
mcollins
Electrical
Jul 27, 2015 10:59 PM
estes53
Jul 20, 2015 10:43 PM
Jul 12, 2015 11:54 AM
