vtec switch?
Old Mar 9, 2008
em2.kid's Avatar
em2.kid will become famous soon enough
vtec switch?
I was out at the races tonight and after the cops came I was hanging out with some friends at 7/11 and someone brought up the idea of a vtec on/off switch. I've head of something like this and attempted to Google to find more info but was lost. Is it possible to turn your vtec on when you want with a switch? I know how vtec works and understand vtec at low rpm's wouldn't work to well but being able to control vtec would be fun in a way.
Old Mar 9, 2008
Re: vtec switch?
very bad idea, you need four conditions to be met (coolant temp, oil pressure, throttle position, and rpm) so that the cam switch happens safely. just flipping a switch when you feel like it = ruined motor and worse performance. the ecu will not pop the solenoid unless the car is fully warmed up, oil pressure is normal, rpm is above 4500, and gas pedal is at 100% throttle.
Old Mar 9, 2008
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
Re: vtec switch?
true story.
Old Mar 9, 2008
Re: vtec switch?
and if you want more technical info, each of the four conditions sends a 3v signal to the ecu. only when you get 3+3+3+3=12v signal sent to the ecu does the ecu then send a 12v signal to the vtec solenoid bolted on the head to switch the cam profile.
Old Mar 9, 2008
em2.kid's Avatar
Re: vtec switch?
Thanks that makes sense I didn't think it was a good idea
Old Mar 9, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: vtec switch?
this is not true. each sensor sends it's own voltage. it's the software in the computer thats makes the desion to turn on the vtec or not.
Old Mar 9, 2008
Re: vtec switch?
isnt that just what i said? all four conditions must be met, and then the ecu pops the solenoid
Old Mar 9, 2008
DieMaster's Avatar
Re: vtec switch?
yes but it's not 3v for each sensor. it's whatever the threshold is for that sensor in the ECU.
Old Mar 9, 2008
Re: vtec switch?
ah okay
Old Mar 11, 2008
DsevenEm2's Avatar
This is Myspace
Re: vtec switch?
yes you did
Dani1993
Jul 24, 2015 09:02 AM
cizsak
Jul 21, 2015 03:39 PM
cukaracha
Jul 17, 2015 05:48 PM
Trennytrent
Jul 10, 2015 09:01 PM
jody501
Jul 10, 2015 11:01 AM
