1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
B20b
Old Mar 31, 2016
Elatria's Avatar
Elatria is an unknown quantity at this point
B20b
How can I check what model B20B engine I have? I know it's from a CRV but I'm not exactly sure what year and the mechanic needs to know before we order parts for it. I need a radiator and a head gasket kit.
ID:	88652   Click image for larger version
ID:	88653   Click image for larger version
ID:	88654   Click image for larger version
Old Mar 31, 2016
Re: B20b
97-01 CRV used that engine.
Head gasket OE#12251-P8R-004 is used on all those years. I did not check any of the other gaskets though.
If you need to know an exact year, do you know who did the swap and can you ask them?
Radiator is for the Civic not the CRV.
Old Mar 31, 2016
Re: B20b
For head gasket SETS there's a difference between 97-98 and 99-01 in the factory catalog. IDK what the exact differences are though and don't have time to research it.
Old Mar 31, 2016
Elatria's Avatar
Re: B20b
Thank you so much! So is there a kit that comes with that head gasket?
And unfortunately I can't get a hold of the previous owner.
Old Mar 31, 2016
Elatria's Avatar
Re: B20b
Alright I'll look into that and thanks a bunch for the help.
Old Mar 31, 2016
Re: B20b
Depends on the year of the engine and where your mech is getting the gasket set from.
A SET from Honda usually includes valve stem seals, and if you aren't doing a valve job you can save cash by buying the individual gaskets separately.
The Honda catalog says the 99-01 set is discontinued, but the earlier year is still available.
If using an aftermarket company, you'll have to see what's available from them.
Old Mar 31, 2016
Re: B20b
See if there is still a VIN tag attached to the engine..... might be right above the oil pan somewhere on the block. Probably on the back side (oil filter side)
If it's still there THAT would give you what you need to know..
Old Mar 31, 2016
Elatria's Avatar
Re: B20b
I'll do that when I get a chance as I'm at work right now. Also what kind of hose would I use for the radiator?
Old Mar 31, 2016
Elatria's Avatar
Re: B20b
Hey so I found this it says p7510 I thought it was supposed to be a p8r?
ID:	88656   Click image for larger version
Old Mar 31, 2016
Re: B20b
A radiator hose.
I didn't build it, you and your mechanic have to figure it out.
Match up what's on there now?
No clue from me. I mostly deal with stock stuff.
Dobber1
Feb 10, 2016 12:51 AM
stopher
Feb 7, 2016 01:23 AM
Niaboc67
Jan 14, 2016 01:09 AM
tw8229
Jan 12, 2016 05:28 PM
Bantymom
Jan 8, 2016 02:38 PM
