1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Help! 94 ex coupe, 5spd, clunking when I accelerate hard
Old Feb 11, 2016
Klame9420's Avatar
Klame9420 is an unknown quantity at this point
I have a 94 ex coupe 5 speed, just swapped motor a few months ago, noticed a small clunk only every now and then when I would take off fast, I new the mounts weren't in the best shape. I recently had to pull the motor again to install a clutch and decided to put all new mounts on while I was at it. Now EVERY time I take off fast I hear a loud clunking that I can also feel through the floor and in the steerin wheel. Almost feels like the rear mount t bracket is smacking the steering rack. At least that's what I've narrowed it down to, but I have brand new mounts so Im 75% it's not that but you never kno. Also thought maybe CV joints, but it doesn't make the noise while turning, only at hard acceleration, can anyone help???
Old Mar 31, 2016
iyzak's Avatar
iyzak is an unknown quantity at this point
Re: Help! 94 ex coupe, 5spd, clunking when I accelerate hard
not a honda guy by any means however I would start with all bushings:
1. Worn motor mount
(although you said you changed)
2. Worn sub frame bushings
3. Worn strut
4. Worn or loose upper strut mount
5. Worn tie rod ends
6. Worn ball joints
7. Worn wheel bearings
is it only when you take off fast or if your driving stay in the same gear and hit the gas does it do it? or when you shift? clutch engaged or not?
E Sully
Jun 2, 2016 09:00 PM
Oct 29, 2015 01:12 AM
Dezso3
Suspension
Oct 7, 2015 05:09 AM
meicalnissyen
Sep 25, 2015 12:12 AM
Joecrowe
Sep 24, 2015 09:12 AM
