1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
cold blooded civic, fast idle issue
Old Jan 16, 2016
ravenator's Avatar
ravenator is an unknown quantity at this point
I have 1993 Civic 1.5 liter automatic transmission with 103k miles. When I start it in the morning it takes 5 minutes for the RPMS to drop down before I can put it in drive or reverse. My question is,what controls how long the engine is on fast idle? if I put it in drive or reverse when it is idling fast, the engine stumbles and almost dies. After its warm, it runs perfect.
Thanks!
Old Jan 16, 2016
Re: cold blooded civic, fast idle issue
Yes it should idle faster while the engine is cold.
The colder it is, the faster the RPM will be.
Idle RPM should slowly come down as the engine warms up.
How fast might be questionable, is yours idling too fast for a given temperature? You may want to compare to an identical car or ask the owner about it.
If coolant level is low, it may not come down correctly.
If the engine can't warm up correctly the idle may not come down correctly.
If the IAC or FITV is bad or stuck, idle may not come down correctly.
If it just runs like poop when you drop it into gear you might want to check basic tune up items. Got any codes?
Old Jan 17, 2016
ravenator's Avatar
Thanks for the response. I understand the engine should run faster when cold, but I think 5 minutes is too long. Normal cars take about 30 seconds and drop down to 600-700 RPM. Coolant level is fine. How do I run codes on a 1993 without OBDII? I might try cleaning the FITV. thanks!
Old Jan 17, 2016
Jumper the SCS connector, read basic flash codes
Old Jan 21, 2016
dustin19d's Avatar
dustin19d is an unknown quantity at this point
A 1993 Civic will not drop down to 600-700 RPM in a minute. Never has, never will, unless you live in the tropics. However, dropping it into Drive or Reverse right after starting it while it's at high idle should not significantly effect the idle. If it does you have a problem. I would start by ensuring you have no air in the coolant, then make sure you don't have a vacuum leak, then I would check and clean the IACV or adjust the FIV. Or watch this
Do you have a CEL light?
alinaray
18
Aug 24, 2015 01:04 PM
cja3455
Aug 24, 2015 06:20 AM
viper775
Dec 9, 2001 10:52 PM
1stcivic
Nov 18, 2001 09:17 PM
Waldo
Nov 10, 2001 01:04 PM
